Cracked Rear Housing on NH TZ18
   / Cracked Rear Housing on NH TZ18 #1
Rich C
I have a TZ18 NH tractor with frontloader & BH that developed a 1" crack on the housing. Replacement with labor is approx. $4,000.00 I am leaning towards having the repair made by welding a plate over the affected part.
Does anyone on the forum know if this is a viable fix? Thanks Fellas
   / Cracked Rear Housing on NH TZ18 #2
I don't know if it would work, but JB Weld claims to perform miracles. If so, I would clean the area super well first.
Thanks BQR..will check it out. Right now my dealer is suggesting I trade the tractor in since he's concerned the Woods BH will just cause another crack. I'm debating what to do.
I appreciate your reply.
   / Cracked Rear Housing on NH TZ18 #5
It would be best if you could post a picture of the location of the crack. That being said, JB weld may, and possibly will work. The rear axle housing undergoes normal "squirm" and flexing by just being driven and used normaly. So does you engine block. Stress is induced by the engine hp and torque applied to the internal componets of the rear axle, which in turn transmits that twisting motion to the outer housing while the power is being applied to the ground as you get along on your tasks.
I would seriously consider welding the housing if the crack has not spread apart the casting. I would also get a good, or even certified welder who is familar with welding with Ni-rod. This is a special high content nickel welding rod specifically for welding cast iron.
If your housing is aluminum, again I would find someone who could TIG weld the crack. Of course the fluid has to be drained, and if the welder is familiar with the technique of burning the oil off while he lays done the repair bead.
Reinforcing the area is also another good idea which has been mentioned.
Even if you have to drain all fluids, flip tractor upside down, it is still better than a complete tear down, parts, labor expense. For what could be another under designed new part, which my fail in the future.
It would be most interesting to see pictures, and try and tell if it is a design flaw, or materials failure. Cast parts do have inclusions cast into them by accident. And every now and then one gets by inspection.
Let us know if we can help you futher. And if you can post some pictures.
Check out forum threads for NH TC 30 + crack in housing. Sounds similar.
TractorByNet.com - Search Results
Yep....TY for the heads up. Good info there & helped make up my mind.
I'm going to trade-in my NH. My dealer gave me a decent price for a new Massey with FL BH & 52 inch deck & will accept the NH as part of the deal.
I appreciate the good help here!
   / Cracked Rear Housing on NH TZ18 #8
What model MF??
Thanks for your reply. The tractor is at my equipment dealer so I am unable to post photos. The housing is cast iron which typically doesn't weld adequately & I'm concerned that having the BH mounted to the housing will eventually create another stress crack. At this point I'll cut my loss & take the trade-in. This latest issue combined with other minor disappointments with NH pushed me to the decision.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
2015 Ford Expedition EL SUV (A51694)
2015 Ford...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
