Cracked KB2485 Sub-frame AGAIN!
   / Cracked KB2485 Sub-frame AGAIN! #11
I would like to see koiti make the sub frame design like club cadet yanmar or deere, the sub frame runs along the side, an bolted on. Also puts the backhoe closer to the tractor.:thumbsup:
Kioti did a better job on the subframe for the LK30 TLB IMO. I really
like the newer Kubota and Woods subframes; Deere, not so much.
   / Cracked KB2485 Sub-frame AGAIN! #12
My Woods BH-70X is a monster, and it's got a subframe and mount to match. Initially, I was buying the tractor with the Kioti BH, but called my dealer back and asked him to add a thumb. He told me that Kioti didn't have a thumb for their backhoe but he could do a Woods BH for an extra $1K with the factory thumb. He also added that in his opinion, the Woods BH was a much better BH because of the subframe mount and that's the only one he'd put on his tractor.
Man am I glad I listened. I never actually saw the Kioti BH installed on a tractor (I had never used one and had already test driven the tractor and didn't figure I knew enough to go back and look at it anyway), but now having seen pictures of the mount I can say it looks very flimsy to me. I would agree with other people, take it to a very good machine shop and have them engineer a new mount that incorporates your existing mount, make it 10X as strong. I know that my BH-70x can pick up the back of my tractor and can pull the tractor around a bit, and that's with loaded tires. There's no way the mount in these pictures is going to take that kind of stress day in and day out.
   / Cracked KB2485 Sub-frame AGAIN! #13
I would not replace the whole thing, as a good welder can beef up and fix your existing one for a fraction of the cost of making a new one.
   / Cracked KB2485 Sub-frame AGAIN! #14
No, neither would I, sorry if I wasn't clear. I would use the existing and simply have an expert reinforce it in a way that will make it much stronger than it ever was.
I'm currently digging 400ft of trench to install some weeping tile to drain off an area that is soggy in the spring. I watched the interaction between the tractor and the backhoe last night and was surprised to see how much flexing was going on. There's so much force put through the mounting bracket, it needs to be extremely strong but allow a little flex. I love welding projects, but this one I'd defer to the pros.
   / Cracked KB2485 Sub-frame AGAIN! #15
KK, you were clear, the OP was considering a replacement. I weld too, but your right, this one I would farm out to an expert.
   / Cracked KB2485 Sub-frame AGAIN! #16
The KIOTI Equipment lists do not show the KB2485 Backhoe on the CK30 subframe. We know they fit...but they are not listed as compatible by KIOTI Tractor. You may have had a warranty issue even during the original warranty period.
So why did the OP buy a larger BH than was recommended by Kioti? Seems they rate them appropriately based on applied loads-I would assume. So the CK-30 is rated for the KB2475; which might not have broken the subframe? Anyone with a CK30 and KB2475 have cracked subframe members?
I just put a KB2475 on my CK30...that is why I ask. Need to baby it?
   / Cracked KB2485 Sub-frame AGAIN! #17
There is one on the youtube, ck30 under barretts equipment. Its a old video, but it has the correct backhoe on. an i think the sub frame was crack in four places. the video was 8 minutes an 15 seconds long.
   / Cracked KB2485 Sub-frame AGAIN! #18
I would weld it up and drill two weep holes in the base of the tubing. The first photo shoes what appears to me as a ballooned tubing rather than typical 2X4 tubing. My thought is that maybe water got inside and either froze or expanded and blew the welds out.
   / Cracked KB2485 Sub-frame AGAIN! #19
So, did you have the 3-point top link attached to the BH?
   / Cracked KB2485 Sub-frame AGAIN! #20
So just how dangerous can this be with the sub-frame breaking like that? I've heard horror stories about the 3pt BH breaking and crushing the operators.
Golf Cart (A55787)
Golf Cart (A55787)
2002 International 9200i Truck (A56435)
2002 International...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2019 Chevrolet Silverado (A55973)
2019 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
9000 (A47477)
9000 (A47477)
