cracked front axle ym2000
   / cracked front axle ym2000 #1
tmil50
Yanmar YM2000
I cracked my front axle and have found a new one but I can't get the wheel spindles off. Has anyone done this before? I'm not sure how I broke it but it must have been awhile ago because of the rusk in the crack. My land was pretty rough when I first got it and have done alot of grading since then.
   / cracked front axle ym2000 #2
You should remove nut #38, then remove steering arms #20 and #21. Then your spindle should knock out with the bottom bearing on it. At least that is what I see from the parts drawing. Yanmar Tractor Parts: FRONT_AXLE_2WD
   / cracked front axle ym2000 #3
I have had mine off a couple of times. If the woodruff key (33) gets out of alignment at all in the slots, it can make it very hard to get off. Good luck.
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2011 DOOSAN ALL TERRAIN FORKLIFT (A53426)
2011 DOOSAN ALL...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A51692)
2015 Ram 5500...
PALLET OF JACKS AND STANDS (A53843)
PALLET OF JACKS...
