Crack in Front Axle on Iseki TX2140 (1410)
   / Crack in Front Axle on Iseki TX2140 (1410) #1
VikingIseki
My tractor has a crack in the shaft tunnel behind the knuckle on the left side (where the shaft tunnel is thinnest) Is this a problem on this model or have i been unlucky???
   / Crack in Front Axle on Iseki TX2140 (1410) #2
I don't know, but I've never heard of it personally. Any good welder should be able to put the fix to it, so long as any seals or other heat sensitive parts near to it are removed, or protected by a wet towel if able.
   / Crack in Front Axle on Iseki TX2140 (1410) #3
It occurs occasionally, usually when a loader is mounted on the tractor.
My tractor has newer had a loader mounted, it has been used mostly for road use, but also some use in the woods in Norway.
Do you know where i can find a new a shaft tunnel behind the knuckle on the left side, and how mutch this will cost?? (all TX models has the same front axle)
   / Crack in Front Axle on Iseki TX2140 (1410) #5
Do a search of my previous post's, I posted a list of parts suppliers, of whom, Leonard Shaeffer is one.
   / Crack in Front Axle on Iseki TX2140 (1410) #6
I can supply you with a housing.
Electric Mobility Scooter (A51694)
Electric Mobility...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
New Long Forks (A53002)
New Long Forks...
HYUNDAI 740-9 (A52472)
