Crack in Front Axle on Iseki TX2140 (1410)
   / Crack in Front Axle on Iseki TX2140 (1410) #1
VikingIseki
My tractor has a crack in the shaft tunnel behind the knuckle on the left side (where the shaft tunnel is thinnest) Is this a problem on this model or have i been unlucky???
   / Crack in Front Axle on Iseki TX2140 (1410) #2
I don't know, but I've never heard of it personally. Any good welder should be able to put the fix to it, so long as any seals or other heat sensitive parts near to it are removed, or protected by a wet towel if able.
   / Crack in Front Axle on Iseki TX2140 (1410) #3
It occurs occasionally, usually when a loader is mounted on the tractor.
My tractor has newer had a loader mounted, it has been used mostly for road use, but also some use in the woods in Norway.
Do you know where i can find a new a shaft tunnel behind the knuckle on the left side, and how mutch this will cost?? (all TX models has the same front axle)
   / Crack in Front Axle on Iseki TX2140 (1410) #5
Do a search of my previous post's, I posted a list of parts suppliers, of whom, Leonard Shaeffer is one.
   / Crack in Front Axle on Iseki TX2140 (1410) #6
I can supply you with a housing.
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
