Crack in Bucket
/ Crack in Bucket #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I found a crack in my FEL bucket. I'd been doing some really heavy duty clearing with the FEL. I successfully cleared 2-3 acres of planted pines that varied in diameter from 2-6 inches, maybe an 8 incher or two. All were young and limber but many of the bigger ones didn't come out of the ground without a fight and I often felt that I was pushing the limits of this little tractor. The result is that the whole area is now cleared down to the dirt, all trees and stumps gone. I've smoothed it out with the box blade now so it is smooth enough to run the mower over (once something comes up to mow).
I saved a lot of money vs hiring the job out to a dozer, etc. It took a long time but I had fun every second of it. The only obvious costs to the tractor were a hole in the radiator (fixed for $80) and this crack in the bucket. The first image shows the cracked welds along the angle iron support:
The second shot is a closeup showing that the crack in the corner is the metal support and not the weld that is cracking:
My B-I-L farmer thinks this came from torquing the bucket. Many times I would hook the corner of the bucket under the roots of a bigger pine and lift it out, or try to. Sometimes it wouldn't come up but the bucket would pop free violently. So he's probably right.
He says he can fix it. He says he'll grind out the crack and re-weld it. Obviously this is hardly a big deal but is evidence that pushing the limits does have its price.
/ Crack in Bucket
/ Crack in Bucket #3
Well, it must be nice to have a BIL like that! He is both smart and helpful. I have to agree, pulling from one side is probably what did the damage. It really isn't that much damage either, remember all metal will fatigue. I think the 600 hour check includes looking for cracks.
Quick weld job and you will be back on the road again. You may want to have him weld on some extra beef and some chain hooks while he has the welder out...
jb
/ Crack in Bucket #4
jb
/ Crack in Bucket #5
Depth perception in hard for me in pics, but it really looks like a cold weld. I think that might be rust around it? It might have been "working" on cracking for a while now.
/ Crack in Bucket #6
/ Crack in Bucket #7
I'm with dubba, looks like pretty poor welding from the start.
/ Crack in Bucket #8
/ Crack in Bucket
That's the first thing that my B-I-L said. (I just assumed it was because he's a Deere man /forums/images/graemlins/grin.gif )
But I agree, the little row of spot welds looks cheap. However, the weld in the corner is very substantial and the metal is cracking in front of the weld not at the weld.
Anyway, I've just got to find the right time to get him to do it. He tells me that he's going to set it all up and teach me how to do it! (Does a bad weld on a bad weld equal one good weld? /forums/images/graemlins/shocked.gif )
In the mean time, I'm still using it, just not in any real high stress situations.
P.S.: The rust came after the crack, at first I noticed the flaking paint and I flipped a piece of it off and it revealed nice shiny metal with a clean shiny crack in it.
/ Crack in Bucket
/ Crack in Bucket #11
</font><font color="blue" class="small">( the metal is cracking in front of the weld not at the weld )</font>
Exactly.. If it was a properly done weld, the edge of the bead would not look like it is flaking off of the metal. The weld should penetrate all the way through the metal.
I think the spot welding across the bucket reinforcement is more than likely an engineered thing. If that was welded solid it might not flex the way the engineer's want it to leading to more damage farther in.
/ Crack in Bucket #12
2016 Ford Transit 350 Cargo Van (A61573)
2016 Ford Transit...
2019 John Deere 314G Compact Wheel Loader Skid Steer (A61572)
2019 John Deere...
2014 Nissan Sentra Sedan (A61574)
2014 Nissan Sentra...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61573)
2012 Toyota Tundra...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
