Cowl Panels
   / Cowl Panels #1
Dobaroy
Ontario, Canada
Ford 3600 3 cyl Gas, MF 65 Perkins Diesel & 1270 White Fiat powered
Having a little problem trying to remove the cowl panels from our Ford 3600, all the rest of the panels came off easy enough. Wonder if anybody has any suggestions.
Good information on this forum, thanks for your help.
   / Cowl Panels #2
You talking about the small steering tins under the dash? 4 pieces in all?
Perhaps you hare having trouble removing the two little front pieces?
The right side should come off easily if you remove the rear pieces first then turn the steering wheel one way or another to get it to slip out from around the sector shaft.
Then you should be able to reach in on top of the tranny and remove the bracket that holds the front tins.
Then remove the left tin. The left side is harder because of the pump.
   / Cowl Panels
Thanks for the reply. We are going to give that a try.
John Deere 5105M (A53317)
John Deere 5105M...
2021 Kubota SVL97-2 (A57148)
2021 Kubota...
Metal Horse Statue (A57454)
Metal Horse Statue...
Cummins 6 Cylinder Power Unit (A57149)
Cummins 6 Cylinder...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
43013 (A59228)
43013 (A59228)
