Cowboy Coffee? Mmmmmmm
   / Cowboy Coffee? Mmmmmmm #31
Cowboy style works for me. but boiling can lead to an acerbic brew. Early on I learned "boiled coffee is spoiled coffee"!
So....
I use the electric percolator, in case I need to offer a cup to any visitor. The basket holds "most" of the grounds in just fine. But that last cup at the end of the pot can get a bit thick.
I drink three cups a day mostly.
I've read that coffee is good for the liver.
The left over pot just sits on the counter. It gets unplugged as soon as the perk is done. Reheat is done in the nuker.
Be sure to use "Folgers" coffee,(Arabica)
"It tastes as good as it Smells"!
   / Cowboy Coffee? Mmmmmmm #32
I remember trying cowboy coffee during a camping trip years ago. It was a fun experience. I found that using a finer grind can help reduce the amount of grounds in the cup. Also, removing the pot from heat before adding the coffee grounds can prevent bitterness. There's something special about that hands-on brewing process. These days, though, I've gotten used to quicker and more convenient options, especially with the instant coffee machine we have in the office. It's not quite the same as the traditional methods, but it gets the job done when time is tight.
   / Cowboy Coffee? Mmmmmmm #34
I'll have to try this. I was always given to understand that boiling water was the cause of bitterness/acidity, not the cure. Hence all the 196° water temp kettles.
Percolators attempt to provide sub boiling water to the coffee grounds.
That is, boiling sends the water up the basket tube, past the relatively cool water in the pot. The "less than boiling" water PERCOLATES through the grounds , extracting the "coffee".
When the body of water reaches the magic temperature, the percolator shuts off.
That is the essence. Reality may be slightly different.
Tap water at my house is reliably 62 degrees in summer, 57 in winter.
The pot shows condensation on filling.
Cool water!
Cowboy coffee is entirely different.
   / Cowboy Coffee? Mmmmmmm #35
If you have the time and patience to make cowboy coffee daily then your living right. ;)
I use the Keurig coffee maker for a sub 1 minute cup of coffee, black and strong.
   / Cowboy Coffee? Mmmmmmm #36
Coming in late, but I thought Cowboy Coffee was made in a coffee can, with a coat hanger as a bail. That's the way my Grandmother used to make it over a campfire. Her and Grandpa called it Cowpoke Coffee.
   / Cowboy Coffee? Mmmmmmm #37
Using an electric percolator is a practical choice to avoid the bitterness of boiled coffee, though the last cup can sometimes hold extra grounds. According to Wikipedia, coffee has long been valued not just for its taste and aroma but also for potential health benefits, including liver support. Just as people refine their brewing methods for better flavor, checking the Olive Garden Menu at / helps diners pick meals that perfectly match their taste and preferences
   / Cowboy Coffee? Mmmmmmm #38
Boiled coffee often turns bitter, which is why percolators or drip methods are preferred for smoother flavor and fewer grounds in the cup. As noted on Wikipedia, coffee consumption has been studied for potential health benefits, including positive effects on the liver when taken in moderation. For those who enjoy exploring different brews and food pairings, checking tim hortons menu prices can be a practical way to enjoy coffee alongside affordable meals.
   / Cowboy Coffee? Mmmmmmm #39
Really?, not bitter?
I used to be a Timmies' addict, in the past month I've noticed it getting a lot weaker, probably the 'shrinkflation' rearing it's head in either they're adding more water or the pouched coffee quantity is less.
I just may try it and yes, I do adulterate it with cream and sugar.....sorry as I understand that is the next best thing to murder for a coffee aficionado :)
Years ago I drank "cowboy coffee" with a shot of bourbon added to the cup. That was a wakeup drink.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2012 Ram 1500 Quad Cab Pickup Truck (A53422)
2012 Ram 1500 Quad...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
