Covering hay
   / Covering hay #21
-great link on hay G4575 Making and Storing Quality Hay | University of Missouri Extension
I have learned some new stuff from this discussion and looking on the net. I didn't know you could use a meter for moisture content.
--What I'm seeing around here is white plastic wrapped round bales in the field. I looked those up and they are balage, like what used to be grass silage I think blown into a silo.
Also there are some farms just south of here making long tubes of this balage that they feed all winter long using a small skidsteer to grab it and feed it to the dairy cattle - holsteins.
Open silos packed with chopped corn are common around here (packed with the tractor) and covered over with a tarp and tires for the winter.
   / Covering hay #22
Some rd hay baler's have moisture testers installed in the side walls to give % moisture reading while hay is entering bale chamber.
   / Covering hay #23
Tx Jim,
Using the moisture meter of yours, how/when do you check? Before baling? After baling a couple?
   / Covering hay #24
I can check in windrow or in the bale. I usually just check the 1st couple of bales and then if weather conditions change I'll check again. Checking in windrow requires changing to a different attachment that the% moisture reading depends a lot on the amount of hand pressure applied to device. Even after all my years of custom baling I wouldn't bale hay without utilizing a moisture tester.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
206320 (A57192)
206320 (A57192)
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
