Covering hay
   / Covering hay #1
Walkin Horse
Platinum Member
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
I got my first loads of hay yesterday and man does it look good. The last couple of years I have been buying it from a guy who would haul it to me when he finished cutting. Sometimes it looked good and sometimes not. But this last year it was full of leaves, thorns, johnson grass and broom straw with the feathers.
The new hay is from a old timer who seems to know what he's doing. He wants it right and the customer happy. This is the first time buying hay that I feel good about it.
Some years I have stacked it on pallets Some years I have tried covering it. Today I cut some pine poles 20' and laid them in pairs 2' apart and laid the bales on them My tractor will straddle them and I dont have to put down and pickup pallets.
Now my question is, at what point should I cover it. Will it hurt to cover it now while the heat is still in it or wait and hope for no rain or cover on bad days and uncover on good days (pita). I have had mix success covering before and I really hate to ruin this and waste it. One time I stacked two layers high and it molded really bad where the bales were touching. What is the right way to store it outside.
   / Covering hay #2
So far my best experience storing hay outside is set it all up like you want it then build a pole barn around it. That usually works out pretty good :thumbsup: Of course that could be cost prohibitive ............ so if the hay is dry 18% or less I cover mine with a way to let air get all around the bales so ground moisture won't collect and ruin the hay. Something like stack pallets beside, and on top to add ventilation.
   / Covering hay #3
in my opinion I think there are alot of variables to how soon you cover hay. ive noticed that when I cover hay that I baled with a higher humidity in the air I have more spoilage than if humidity is down. to be on the safe side I always left my uncovered for a few days after I rolled it. if it was dry and humidity was low when its baled you can cover it as soon as you want. thats when the moisture in the bale should be below 18%. then I stack mine tight and stack 3 rolls on bottom two in the middle and 1 on top. then I cover with a good tarp that comes halfway down the bottom bale and leave both ends open. its important to keep the tarp completely tight so water cant stand on any of it.
   / Covering hay #4
This is my opinion, and my opinion only, but I feel that if hay is putting off enough heat that it can't safely be covered, it was rolled/baled too soon with too much moisture. Yes, I've known of folks who had their barns burn down because they stacked it full of hay. Sure, there are bound to be circumstances where it is preferable to bale the hay a little wet for fear of it getting even wetter (i.e. rain's coming tomorrow). But in general, if I don't think it is dry enough to stack in the barn the day I bale or roll it, I'm not going to bale/roll it unless the weather dictates such.
If you are afraid of it getting too hot, I would just let it set in the open uncovered until you're comfortable covering. I'm assuming its rolls of hay, given your description of storing it on poles, and a good roll should shed rain water pretty good, so it won't absorb much if it gets rained on a couple of times.
Good luck and take care.
   / Covering hay
I checked this morning before I left and it didn't have the heat it had Tues. So I will start covering this weekend.
I have tried stacking it to save room but it seems to mold where it cradles. I got 40 bales so far and need another 110. Hope this weather we are having holds out. Last night north of here in Richmond there was terrible storms but nothing 25 miles south.
   / Covering hay #6
AMEN BUDDY. It amazes me the people that pyramid & stack rows of rd bales with the sides touching. Rd bales if baled correctly by a good baler & if stacked correctly will SHED WATER!!!!!
   / Covering hay
Is it okay to shove the end tight together. I leave 2 or 3' between rows
   / Covering hay #8
If hay was baled at correct moisture content(IMHO 15%<) then butting bales end to end tightly with rows spaced 1+ ft apart slows spoilage. Another rd bale storage MISTAKE I've seen my neighbors commit is storing rd bales under trees.
   / Covering hay #9
If hay is producing heat after it is baled- baled too early. It will begin to mold over the winter and get dusty.
   / Covering hay #10
Hay baled at correct moisture(around 15%)will go through a heat cycle. The heat cycle gives the hay a good,sweet odor that animals like.
400 gal Fuel Barrel on Skid (A50515)
400 gal Fuel...
2016 Kubota SSV75 Skidloader (RIDE AND DRIVE) (A50774)
2016 Kubota SSV75...
1981 FMC Link Belt Crane (A50120)
1981 FMC Link Belt...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
2121 (A51244)
2121 (A51244)
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
