Couple of comments on Enrossi sickle bar
   / Couple of comments on Enrossi sickle bar #1
Pote
Kubota, Ford
Used my Enorossi BFS 180 for the first time today. A couple of thoughts:
Why cant they come up with a proper stand so it can be mounted/dismounted level? There is a kickstand for the left side, but the right side is not level. WTF. looking at some pix on the web, a guy propped his up on a pallet with a cinder block under the right side. Any home made docking station ideas will be welcomed!
This does not fit a Titan quick hitch so any hope of an easy connect is lost for me.
Once connected, it's a beast down the ditch line, but I only see myself fighting with it once or twice a year. It was pretty expensive so I hope it lasts 25 or more years.
Would love to see someone invent a heavy duty PTO boom articulated string trimmer for ditch/pond banks.
   / Couple of comments on Enrossi sickle bar #2
I have a First Choice sickle bar. It is the hardest implement for me to hook up.Heavy, awkward, and unstable when on the ground. But it gets easier. With time you develop a better system. For a kick stand I have a vertical pipe with several cross holes in it that slides up and down inside a short section of larger pipe with a cross hole that is welded to the mower frame. It allows me to adjust the kick stand as required with a pin through the holes. Maybe something like that would help.
gg
Thx for the encouragement. Can you snap a pic of your stand when you get a chance? Sounds promising
   / Couple of comments on Enrossi sickle bar #4
This is a picture of my mower. The stand is the silver pipe sticking up on the left side. It is like an inverted "T" that drops down. Tomorrow I will go out to the field where it is sitting and get a better picture.
gg
   / Couple of comments on Enrossi sickle bar #5
The way that works for me goes like this: I bring a 5' pry bar with me. A piece of pipe will work. I back in and hook up the inside (Right) lift arm first. (Note: My left lift link is the adjustable one). To line up the left lift arm with the pin I make vertical adjustments by raising or lowering the adjustable lift link and/or raising or lowering the 3ph a little. To make horizontal adjustments I use the pry bar out on the end of the cutter to rotate it forward or backward using the already connected right lift arm as a fulcrum and thus moving the outside or left pin horizontally back or forward. Some times it helps the lift the 3ph a tad to get some weight off the ground. If that doesn't work as a last resort I carefully move the tractor forward or back ward a hair. If I get out there and have forgotten the 5' bar I don't even try. I have in the past but it usually is much easier for me to go back and get the bar than to struggle w/o it.
gg
   / Couple of comments on Enrossi sickle bar #6
That's funny the BFS 210 I just got has the T stand as standard. While it's not a walk in the park to hitch/unhitch, that does help. They also have a little pivot tab that takes up a lot of the opposite side weight to the T so that unhitching is possible. My biggest gripe is the outboard hay deflector flag that when upright is at perfect head height. I hit that about 4 times before I learned otherwise! Do any of you have hydraulic lift? I cannot figure out where to tap the hydraulics for it on my 955 Deere.(see hydraulics post).
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
Lone Star dump trailer (A55973)
Lone Star dump...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
