RobJ
Elite Member
I always like to have gauges to see what's going on so I added a few to the L2500. I really wanted a temp gauge but at first I couldn't track down what I needed. So I added an oil pressure and a amp meter. Then a little more digging and I found the P/N's for the temp gauge and sender. The sender being Kubota I guess I had to stick with the kubota gauge, would have rather had some numbers but something is better than nothing. Except for the temp gauge, the others are run of the mill auto part gauges, $10-$15. The temp sender ran about $8 and the gauge was about $50. The temp sender goes in the head, back right side if your sitting on the tractor. Sort of looks like it should be a head bolt but it's not, a 12mm if I recall, headbolts are 14mm. Oil pressure seems to run about 50 most of the time, sometimes a little less depending on the RPM. Don't think I've seen it go lower than 30-35 at a hot low idle.
