MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,655
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I went back over to take a look at it. The channel where the tines are looks pretty heavy duty( 2 pieces sandwiched together). My guess is the tube that it pivots on is the weak point. I can not tell how thick the wall is. Does any know if this is the case?
This may be the case for the unit you are looking at. I did not have that exact same unit, but I did have one that had that same setup for holding the tines. I would bet that the TSC rake has the same setup, channel is 3/16"-1/4" at best. Now my rake was 8' wide, so a lot of stress can be applied in that width. My opinion is with your 50hp tractor, the 6' unit is to narrow and either a 7' or 8' unit would serve you best.
Just my :2cents:, good luck with whatever you end up with. :thumbsup:
