County Line(TSC) Landscape rake
   / County Line(TSC) Landscape rake #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I was over at TSC lookinag at their 6ft landscape rake. I can get it out the door for $450. It appears well built. Made by Tarter in the USA. I did some reading here about the the brand and alot like them and some hate them. It says rated up to 40hp tractor. Mine is a 50hp. Has anyone used this rake on a tractor my size? If i use it within its limits will it perform as needed? What are the weak spots that will possibly need reinforcement? Yes, I have been looking for a used better quality one with no luck. I am also not willing to spend 700 or 1000 for a better quality new one. I will be using it to clean up a couple of acres that I just cleared of trees. Thanks
   / County Line(TSC) Landscape rake #2
Can't offer any insight to the Tater Landscape rake, but I did have a Tater Boxblade. I racked the support frame and tried to replace after straightening them several times. Tater (only sells through TSC) wanted $275 for replacement. I felt the racked pretty easily and the replacement cost was extreme considering the cost of the unit. I sold it for scrap and just bought a heavy duty boxblade. I know this doesn't directly answer your question, but just my experience with Tater.
For cleaning up just a couple of acres it may be the perfect unit. Hopefully others that have used the rakes can give you better direction.
   / County Line(TSC) Landscape rake #3
ITs a rake. Not a hard working piece of dirt moving equipment that engages in the ground and can tear things up. Nothing wrong with the TSC rakes IMO
   / County Line(TSC) Landscape rake #4
I was looking at the same thing last year. I went with the Everything Attachments unit. Its pushing $700 but the tine support is Much better and the offset feature adds significant utility.
   / County Line(TSC) Landscape rake #5
The top channel that holds the tines, ends up twisting like a churro. If you use it for very light work, it may be fine, but it sounds like you have some serious clean up to do, I would look at others. Unfortunately I doubt that you will find what you actually need for the $$$ that you are willing to spend. :(
Good luck. ;)
Good luck. ;)
I went back over to take a look at it. The channel where the tines are looks pretty heavy duty( 2 pieces sandwiched together). My guess is the tube that it pivots on is the weak point. I can not tell how thick the wall is. Does any know if this is the case?
   / County Line(TSC) Landscape rake #7
I own both an excellent ETA Landscape Rake AND a Ratchet Rake bucket attachment.
For piling/pushing brush and tree debris a Ratchet Rake out front on your bucket is both more effective and easier to use than a Landscape Rake.
Ratchet Rakes are sold by the T-B-N store, button in the black ribbon at top of this page.
I already have the ETA single lid wicked grapple for brush. I figured the landscape rake would be better for clean up than the grapple.
   / County Line(TSC) Landscape rake #9
Liberty,
I have the 5ft rake from TSC and like it very much. While I did remove some brambles with it while using it to comb trash out of the brush it is not for heavy duty scrub brush removal. That Ratchet Rake looks a lot better suited for that.
After plowing up a small opening with my Middlebuster Plow I used the TSC rake to collect the busted roots I revealed during the plowing. Because it easily spins around I also used it to push everything up in reverse into a nice burn pile.
The only criticizm I have it that for some reason the channel in the main beam tends to hold water and I haven't found a good way to drain it out although some seems to come out when you reposition the angle of the rake. How the rain gets in there is a mystery too.
Regards,
Clay
   / County Line(TSC) Landscape rake #10
"I already have the ETA single lid wicked grapple for brush. I figured the landscape rake would be better for clean up than the grapple."
I do not have a grapple.
A Ratchet Rake tops a Landscape Rake for the use you have specified plus Ratchet Rake is cheaper and nearly indestructible.
((You listed two concerns about TSC Landscape Rake: price and weakness.))
After debris is piled the grapple will be wonderful for moving debris to a burn pile or trailer.
BUNDLE OF 96" X 40" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 96" X...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2019 BOBCAT E50 EXCAVATOR (A52705)
2019 BOBCAT E50...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
201865 (A54756)
201865 (A54756)
