Counterweight in s770
   / Counterweight in s770 #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
Anyone know how much the belly counterweight weighs in the s770? I was quoted about 10 hours to take it out to reduce machine weight. I'm nearly at my max on my trailer and when I upgrade my s750 to a 770, I just don't need the extra weight, wear on tires, etc. I do want the few extra hp for my mulcher, though.
My s750, with bucket and cab and AC on the scales with 66" industrial grapple is 9200 lbs. I don't want to tow a 10k lb skid steer if I don't have to and I'm looking at shedding that weight.
Thanks.
   / Counterweight in s770 #2
Everything on these 2 machines is identical except the HO rating and the added frame weight. Listed operating weight of standard S750 is 8730# and S770 is 9175# leaves a difference of 445# for the counterweights.
Thanks Doxie, I figured you would know for sure. When I had mine weighed, with an industrial grapple, severe duty tires and A/C, my 750 tipped the scales at 9200 lbs even. I imagine the 770 with AC would be somewhere around 9500lbs if I didn't strip some weight. I remember how the 963 used to wear out tires and trailers. I wish Bobcat gave me the option of 92 hp WITHOUT all the extra counterweight. Heck, put the 92 hp in a smaller frame machine. I just want it to support my pump for mulching.
You hear anything good about the Doosan motor coming? I'm hoping the weight stays the same and there really is a little increase in torque and maybe hp.
2018 Ford F-350 4x4 Crew Cab Service Truck (A51692)
2018 Ford F-350...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
1969 Ford Continental (A51694)
1969 Ford...
Sullair 185 (A50123)
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
