Coulters for my 4 blade plow
   / Coulters for my 4 blade plow #1
Allenfarm
Ruston, Louisiana
Kabota M7040
Does anyone know where I can get 4 coulters for this plow. It's a massey model 74. The Massey dealer where I live wanted to charge me $400 a piece, not even close to reasonable!
   / Coulters for my 4 blade plow #2
That looks a lot like the Ford 101 plow we had which was actually made by Taylor Pittsburgh(?). I could only find this lame website that only has contact info for them: TAYLOR PITTSBURGH (Taylor-Way) HOME PAGE
I did find this site for Ford 101 parts:
New Holland 101-SERIES Section 011 COULTER & JOINTER ASSEMBLIES - 10-350,10-351,10-352,10-353
But digging around there I see a lot of "Out of stock" listings.
I noticed your MF 74 also looks a lot like a King Kutter, although they only come in one or two bottom configurations. However, I wonder if the coulter assembly ($155/ea) would fit.
http://www.kingkutter.com/store-parts.aspx?id=7193
   / Coulters for my 4 blade plow #3
I doubt if you will find counters, certainly not new ones. Even if you luck into used ones (unlikely) the price will be outrageous. I use my 3 bottom Ford 101 without counters and it works fine. If you must have counters, you would be more likely to find another old plow with them that you can either replace your plow with or transfer them to yours. Counters are really not necessary in my opinion.
Dbear, I appreciate the info! I'll look into this today! This will help a lot with cutting through the grass and roots.
   / Coulters for my 4 blade plow #5
Don't have a horse in there race but in past I have found coulter assembles complete here. Knotched or smooth.
DN Equipment
Boone
These things are very hard to find! The plow is great for keeping the fields broken up and the soil loose, which is important down here in Louisiana because if the soil is not turned over every year the soil gets brick hard.
I would like to have the coulters to help cut through the remainder of the plants and roots.
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
CAT 420F2 IT (A50854)
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
