Cost of tiller for BX
   / Cost of tiller for BX #1
Anonymous Poster
Epic Contributor
Anyone have an idea of the cost of the rototiller for the BX. I'm thinking of adding one into the negotiations for a new tractor.
Also, will the BX handle a 5' tiller like the generic ones I've seen at local "Tractor Supply" stores.
   / Cost of tiller for BX #3
MarkH -
I just purchased a Howard Rotovator3, 48inch tiller for my BX2200. $1400, tho' they can be had for a couple hundred less. I had the same dilemma as you a coulpe months back. The small tiller from TSC costs a couple hundred more than the 5' tiller and I wasn't sure the BX could handle it. Those KingKutters tillers at TSC look well made to me.
My experience w/ the BX+howard 4' tiller in my medium clay soil is that it just eats it up with no trouble at all, even with wet soil. If the BX will handle the extra weight on the rear lift and your soil isn't worse than mine (tough to get a hand shovel in mine when dry) you should be able the use the 5' tiller - no problem.
Tho' the BX is small, it does have as much HP to the rear PTO as many of the bigger compact Kubota's.
-Stephen
   / Cost of tiller for BX #4
Like Steve, I have a Howard Rotavator HR-3, though mine is the 52" version, for which I paid $1350. It goes through hard clay like butter...just fine for my BX.
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
UNUSED DIGGIT 72" HYD MULCHING HEAD (A54757)
UNUSED DIGGIT 72"...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2017 Ford F-750 Altec LR758 58FT Insulated Bucket Truck (A52377)
2017 Ford F-750...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
