Cost of steel
   / Cost of steel #1
Rusty4242
Western Mass.
Kubota BX23
I've been poking round in scrap yards for steel for my splitter. What can I expect to pay for new steel from a dealer, square tubing, heavy angle iron , plate, etc.
A buck a lb. ? Larry
   / Cost of steel #2
I was paying .75/ lb. for "drops" last year.
I think a buck/ lb. would be as good as it gets now.
   / Cost of steel #4
I really doubt you will even begin to touch anything from a new metal supplier (not talking scrap dealer) for $1.00/LB. I get my metal from the local scrap yard exclusively. It has always surprised me how much new material is available there. Up until a year ago he charged me 25 cents a pound across the board- it could be a piece of crappy rusted cast iron, a new sheet of 3/8", angle, tube, channel or whatever, it was a flat 25 cents/LB. Now he seems a lot more particular, he might charge me 50 cents/LB for somethings or it may be priced by the sq. ft or linear feet. I occasionally look at new metal from suppliers but am always shocked by the price...for instance I just priced some 2-1/2 x 2-1/2 x 3/16 x 48" tubing for $29.00 from a supplier. The scrap yard might charge me $6.00- $8.00 for a similar piece. If you have a scrap yard locally, I would check to see what they have first and go to a metal supplier as a last resort.
   / Cost of steel #6
In the Solar thread in "Projects" the OP said his full lengths of 6" dia schedule 40 pipe to be used as collector mounts were nearly $600 ea. OUCH!
   / Cost of steel #7
"Drops" are the steel, (all different sizes), that hits the floor after they, (the fabricator/supplier), cut off the piece they need. Its all brand new steel. But, its limited to what is on hand. If a shop is busy enough, you can sometimes get a pretty good selection. I get either what I need, or something I can use, about 90% of the time.
When it was .50/lb. I used to go once a month, and buy 80-100 lbs. so, I have a pretty good selection of angles, tube, and plate, on hand.
Its nice when you have a piece that is just right for the job, without even cutting it. :D
   / Cost of steel #8
I buy mostly drops from my local fab shop. The give me a good deal.
I paid by the pound from a guide book that lists weight per foot of material.
For drops I figure I usually get charged about half, ie I pay for 1 foot when the piece is really 2 feet.
I think he mentioned something like 1.27 a pound but I could be wrong there.
   / Cost of steel #9
I always scrounge through the remnant section and get HRS or CRS for at least half of what they sell new. Last Winter HRS rems were $55lb. CRS is slightly more. I buy entire lengths and cut them myself, or they will charge 5 bucks a cut. Most of my projects are dictated by what I can get. Then I design around that to make ends meet....usually that means a little more thinking and labor on my part, but that is free.:)
   / Cost of steel #10
I hope you mean .55 and not $55 /lb. :eek:
1271 (A50490)
1271 (A50490)
ALLIANCE 15' HEAD CART (A51247)
ALLIANCE 15' HEAD...
2004 DYNAPAC CA152PD PADFOOT ROLLER (A51246)
2004 DYNAPAC...
Unused 2025 SDLANCH SDLL30 Mini Track Loader Skid Steer (A51691)
Unused 2025...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
