Cost of air filters
   / Cost of air filters #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
Why are air filters so expensive? I just bought a primary (outer) filter element for my TD29D and it cost $34! Is that typical for a diesel (do diesels have to have cleaner air?) or is it just because the volume is so low? Or NH just gouging us?!
   / Cost of air filters #2
That's typical for NH, not sure about the others. Make sure you keep the old one you removed and clean it out. I suggest you wait until it's noticeably dirty to swap then, then take the old one out and wash, not blow it clean. Usually I do this by filling a large tub or bucket with very warm, but not hot, water, and lots and lots (about a 1/2 to a full cup) of liquid detergent, and let it soak for about 1/2 hour. (fill the bucket/tub first and then stir in the detergent - otherwise you'll end up with a ton of suds and little or no water.) After, soaking wash the filter by lifting it in and out of the water so that the water is flowing as much as possible from inside the filter to out. Once clean rinse it thouroughly including at least once putting it in a tub of clean water to finish the process. Hang it to dry. Make sure it's hung somewhere were drying will occur within the day. I've washed my old Ford 1720 filters numerous times like this. Just make sure to be gentle throughout the process so as not to damage the filter. Whatever you do, do not use anything like compressed air on the filter while wet.
Wacker Tamper (A47384)
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
(6) MF Suitcase Weights (A50515)
(6) MF Suitcase...
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
