Oil & Fuel Cost of 50 hr service at Dealer for B2650 vs doing it yourself?
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
Curious on what the going cost for the 50hr service on my new Kubota will be at the Dealer here in Greensboro? I may have them do it this one time. They want $350 to just ballast the rear tires so I shudder to ask what he may want for the 50 hour service. Replacing the Hydraulics, engine oil and front axle oil doesn't look too tough to do. It's just time and work and $ for oils.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #2
I'd say just do the service yourself and save the money. You'll also learn a bit about your tractor and have satisfaction it was done right.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #3
I agree and all that needs to be replaced is the engine oil and oil filter and one hyd filter. Check your owners manual. Easy, easy job.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #6
Some of the videos on YouTube show changing out hyd fluid at 50 hrs, but that is incorrect -- you just need to change the filter(s). So be sure to review what the owners manual calls for, and don't make it harder than it needs to be. Swapping filters is easy. Changing out the fluid, properly, gets more involved since there multiple drain points and it's a good amount of fluid ($$).
One of the videos I saw, the guy went through a tremendous amount of trouble to do something unnecessary in changing the fluid at 50 hrs, and he didn't even do it right (missed some of the multiple drain plugs so the math didn't work out). So like anything on the internet, be careful what you believe.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #7
The dealer is going to charge you at least $100 per hour for labor plus shop supplies is always put in to about 5%? of the cost (usually shop supplies is a fixed fee based on some % of total cost) to cover cost of clean up and oil disposal fees.
Then you have the transportation cost to get the tractor to the dealer. You can easily triple or more the cost of oil and filters rather than do it yourself. Even if you have to buy the used oil container and tools to remove the filter and any drain plugs, it will be much less to do it yourself.
Engine oil change is a 15 minute job at most, at least after you get the oil filter off that has been installed at the factory by a 1000 pound gorilla. Be sure to have a good set of filter pliers to get it off. Look at the drain plug or plugs (many 4 wheel drive units will have 2, one on each side of the front drive shaft). My LS required a hex wrench of about 18mm IIRC, in any case much larger than anything I had so I had to find something to fit it before completing the oil change. The oil filter was a real beatch to get off also and I almost destroyed my filter wrench getting it off. Most folks complain about the same problem with super tight filters so be aware of that.
When changing the HST filter, remove the fill cap and insert a shop vacuum hose in the hole to put a vacuum on the reservoir, then you should loose much oil during the swap of filters. IF you don't do this, oil is going to be pouring out of the reservoir until you get the new filter installed.
Still even with all the potential issues, it is a rewarding experience and insightful gains into your tractors workings to do the service yourself.
You should check the front axle oil level as many have found it to be low after running it for a while.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #8
Interesting how some tractors need that shop vac trick. I did the 50 hour service on my B2650HSDC without the shop vac....lost about a 1/4 cup of transmission fluid plus what was in the filter...Just left the dip stick in.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #9
Recently did my B2620 and if I remember correctly there are 2 hyd filters and only one gets changed at the 50 hours and it is not below the standing level of the fluid so only fluid lost is from inside the filter. I think that's right.
   / Cost of 50 hr service at Dealer for B2650 vs doing it yourself? #10
I just parked sideways on a hill with the filter "uphill". Didn't lose more than a few drops of fluid.
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
2006 Ford F-150 Crew Cab Pickup Truck (A50323)
2006 Ford F-150...
