Cost for splitting an AC185
   / Cost for splitting an AC185 #1
Geraldt
fort valley ga
kubota L4350
Oil is streaming out the bell housing drain hole on my AC185. I know the tractor will have to be split to replace a seal. How expensive is it to split a big tractor like this one? Thanks for any assistance.
   / Cost for splitting an AC185 #2
I suppose your talking about a shop to do the splitting?
If you do it your self it is just the time spent.
You can go to most shops that does that kind of work and get a estmate as they charge so much per hour and there is normally a set amount of hours to split the tractor.
Installing a engine seal would be extra.
They may be able to just drop the oil pan and put in a rear main engine seal also.
:D Al
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
