Cost for posthole digger
/ Cost for posthole digger #1
PLOWER
Wisconsin
JD 4710 JD Lt133 JD 345
I'm getting a posthole digger for my 4100 and i was wondering whats a good price.
/ Cost for posthole digger #2
Plower, you'll have to decide how heavy duty a one you want. I've seen new ones from $495 (usually more though) to around $1,500.
I got interrupted while I was doing this message. Northern Tool has a 3-point post hole digger for $349.99 plus $86.99 to $104.99 each for different size augers. That's about the cheapest one I know of (of course, there's probably a reason it's cheap).
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 11/6/00 03:11 PM.</FONT></P>
/ Cost for posthole digger #3
Plower,
Last December I need a posthole digger. I did a lot of looking around. Almost all of the less expensive ones had what looked like the same gear box. The ears on top looked too light. I finely went with a Bush Hog 2101 with 9" bear claw auger. It is a fine piece of equipment, that I'm real happy with. BWY, I paid $635, the area Bush Hog rep. couldn't believe that I got it that cheap.
JerryG
/ Cost for posthole digger #4
Bird hit it on the head. It depends on the quality and options if any on the digger. Also depends on what auger bit you go with---vary in price quite abit and you usually get what you pay for. If it seems too cheap it more than likely is unless it's a brand name.
I bought a slightly used Danuser F-8 for $800.00 with two bits and I thought that was a screamin deal. Prices vary along with time of year and demand.
Gordon
/ Cost for posthole digger #5
Gordon, have you priced a hydraulic power down ram kit for your F-8 Danuser post hole digger?
thanks,
george
/ Cost for posthole digger #6
No I have not but Mark just put one on his maybe we can get him to give us an idea as to cost. But you know as well as I do if it says Danuser it doesn't come cheap. By the same token if the use that I've given mine so far is any indication of how its built. Its bullet proof!!!
I would love to get a step auger for tree planting, another of my many wants or should I say needs.
Have you looked into price on the kit?
Gordon
/ Cost for posthole digger #7
The Danuser downforce kit is about $400. And well worth it if you're digging in difficult conditions.
MarkC
/ Cost for posthole digger #8
As always thanks for the info Mark! Guess that says it all if your working in difficult conditions. How much time do you think it saves you on a hole and do you shear alot more bolts using it?
Gordon
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
520/85R46 MICHELIN TIRE (A64278)
520/85R46 MICHELIN...
MACDON FD235 - 35' DRAPER HEAD (A64278)
MACDON FD235 - 35'...
6' SCRAPE BLADE W/ SLIDE, 3PT (A64278)
6' SCRAPE BLADE W/...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2015 Ram 5500 RKI 10ft. Utility Flatbed Truck (A64194)
2015 Ram 5500 RKI...
