Cosmo Mixer hydraulic cylinder leak
   / Cosmo Mixer hydraulic cylinder leak #1
michael.white
Dripping Springs, Texas
New Holland TC30
Hi all,
I picked up a used Cosmo Mixer 80 and the hydraulic cylinder drips near the non-moving end. There appears to be a bit of a seem near that end, but it's a bit difficult to tell with the rust/age. There no obvious way to disassemble the cylinder - both ends are round with no place to put a wrench or any other tool. Is anyone familiar with these things? The cylinder is about $200 to replace - is it possible to repair the cylinder or are the components pressed together and pretty much disposable?
Thanks!
   / Cosmo Mixer hydraulic cylinder leak #2
What is the bore and stroke of that cyl?
You should be able to get a cyl that will push/pull for less than $100 or less.
Surplus Center
   / Cosmo Mixer hydraulic cylinder leak #3
Mike,
Can you post pix?
   / Cosmo Mixer hydraulic cylinder leak #4
$100 for the original.
Cosmo 35791 Hydraulic Cylinder 3 Point Concrete Mixer | eBay
It appears to be a fixed welded end that you have leaking. I would replace the cylinder if that is the case. The rod side end has a threaded nut that you use a single pin spanner or gland nut spanner (two pins) to remove.
JJ - I'll keep that in mind if the ebay listing falls through.
wdchyd - It looks pretty much like the one in the ebay listing ishiboo posted, just covered in rust.
ishiboo - The rod side end is dry; it's coming from near the fixed end. Thanks for the link!
   / Cosmo Mixer hydraulic cylinder leak #6
Like ishiboo said your base plate welded to the cyl barrel is cracked
It can come apart, machine down and be rewelded, but you'll need a good welder and a seal kit to go back together for the best results
   / Cosmo Mixer hydraulic cylinder leak #7
+1. It's probably not cost effective to have it professionally welded and the seal kit replaced when you can have a new one for $130. If you or a buddy have a welder though, you could attempt a temporary fix as it'd cost you about 5 cents in MIG wire, but the first step would be to wire brush it and see where it's leaking from and how bad it looks.
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
Powder River Squeeze Chute (A55218)
Powder River...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
GALFRE GS300/2 - 2 Wheel Rotary Hay Tedder (A55218)
GALFRE GS300/2 - 2...
