Oil & Fuel Corroded drain plug
/ Corroded drain plug #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
Not sure what got ahold of this drain plug! I think it looks worse than it is. Not leaking any. I assume it is a tapered thread, so it seals on the threads and not the "rim". The allen innerds should still be fine best I can tell.
Since it's behind the "split pin" I also assume that it is HST/hydraulic. I'll replace it at the next (due soon) HST fluid change, if only I can find the Kubota p/n and afford it. Whattya figure, about $25?
/ Corroded drain plug #2
The plug on the right with the paint scraped off is a plastic plug just keeping dirt out of the tapped hole like the other 3 , The drain plug is the recessed one in the center
/ Corroded drain plug #3
I believe that is the remnants of a plastic plug they stick in tapped holes, as Peter has said. The plugs keep paint from getting in and coating the threads when the engine/trans is painted, and they will keep crap out afterwards. I wouldn't worry about it at all.
/ Corroded drain plug #4
Do what IH did back in the 50s...stick a cork in it.
Ah... makes perfect sense. Thanks guys!
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
Caterpillar 259D (A62180)
Caterpillar 259D...
Craftsman tool box with topper (A64047)
Craftsman tool box...
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
UNUSED 2026 INDUSTRIAS AMERICA 7014 7'X14' DUMP TR (A62130)
UNUSED 2026...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
