Mowing Correct Mounting Brackets for a 60" MMM on a JD790
   / Correct Mounting Brackets for a 60" MMM on a JD790 #1
n2deep20
Great web site!!!
I have a few questions about the correct mounting links/arms for a 60" MMM on a 790. The tractor has the usual two arm mount in the front and the two turnbuckle type brackets that attach to the three point in the back.
I have a manual for the MMM and researched the JP parts diagrams without a lot of luck, not much detail and in fact some of the part diagrams show an intermediate link? I tried the local JD store but they are not a lot of help these days as they are a combination lumber and JD store.
I would appreciate a picture of your mower attachment links.
The final question is do you compensate/adjust your mower levelness for running the PTO.
   / Correct Mounting Brackets for a 60" MMM on a JD790 #2
Welcome to TBN! It is a great website.
Are you missing these straps? If so, then yes you are missing a major part of the lift system.
   / Correct Mounting Brackets for a 60" MMM on a JD790 #3
Your links should be very similar to mine. Also, not sure what your question is about leveling for the PTO?
   / Correct Mounting Brackets for a 60" MMM on a JD790 #4
The level mower deck question is a good one. The answer is no, you need not worry about the mower gearbox input shaft always being parallel to the transmission output shaft. There are 2 Cardan type joints in the prop shaft which very nearly eliminates all shaft speed variations as the shaft turns. You should not feel any wobble vibration no matter what height or attack angle you set the mower to.
   / Correct Mounting Brackets for a 60" MMM on a JD790 #5
True that the Cardan joints will eliminate any driveshaft rotation issues. If the concern is keeping the deck level, the lack of center draft arms would be a big problem. Those arms along with the front mount arms create a parallelogram so when it is lifted at the back the deck stays level by also moving rearward. Otherwise it is going to tilt.
   / Correct Mounting Brackets for a 60" MMM on a JD790 #6
I just went through these mental gymnastics this spring putting a MMM on my 770. Same setup as your 790; in fact, the mower I bought came off of a 790.
It won't lift without those center links.
PM me with your email and I'll send you the pictures of mine.
   / Correct Mounting Brackets for a 60" MMM on a JD790 #7
You have mail.
dklistul
Thanks,, the pictures are great and truly appreciated.
Thanks
N2deep20
5004 (A55851)
5004 (A55851)
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2015 Peterbilt 567 (A55973)
2015 Peterbilt 567...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
