Correct fluid level for 1920 4x4 front axle ?
   / Correct fluid level for 1920 4x4 front axle ? #1
2dawoodz
The manual states the fluid level should be b/w the mark on dip stick and lower end of the dip stick. The only "mark" I see on the dip stick is the etched last 1/4". So is the correct fluid level up to but not above the etched end section of the dip stick?
   / Correct fluid level for 1920 4x4 front axle ? #2
I think that's the correct level. My 2120 has a similar dipstick and it just not what we're used to. It does make sense, in a way: if you see nothing wet, you know it's low. You just don't know HOW low and that's annoying.
Jim
   / Correct fluid level for 1920 4x4 front axle ? #3
i ran mine with oil tot he level of the mark on the short stick, when on level ground.
never had an issue.
DO NOT overfill.
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
UNUSED JCT HD HYD BACKHOE ARM (A51248)
UNUSED JCT HD HYD...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
