Correct fluid level for 1920 4x4 front axle ?
   / Correct fluid level for 1920 4x4 front axle ? #1
2dawoodz
Bronze Member
The manual states the fluid level should be b/w the mark on dip stick and lower end of the dip stick. The only "mark" I see on the dip stick is the etched last 1/4". So is the correct fluid level up to but not above the etched end section of the dip stick?
   / Correct fluid level for 1920 4x4 front axle ? #2
I think that's the correct level. My 2120 has a similar dipstick and it just not what we're used to. It does make sense, in a way: if you see nothing wet, you know it's low. You just don't know HOW low and that's annoying.
Jim
   / Correct fluid level for 1920 4x4 front axle ? #3
i ran mine with oil tot he level of the mark on the short stick, when on level ground.
never had an issue.
DO NOT overfill.
434669 (A48836)
434669 (A48836)
7033 (A51691)
7033 (A51691)
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
Informational Lot - Financing (A53472)
Informational Lot...
