Correct clutch kit for MF65
/ Correct clutch kit for MF65 #1
oilystairs
Faget Abbatial, France
MF65 Mk2
Hi,
Would anyone be able to tell me which clutch kit i need to order for my MF65? Apparently there are two types depending on the number of springs (6 spring 11 inch clutch or 9 spring 9 and 11 inch clutch) I can't split the tractor at this stage to see the one i need and i wondered if anyone knows whether i can match the serial number on my tractor to the type of clutch?
/ Correct clutch kit for MF65 #2
Here in the u.s we use the 9spring 11 in the only difference was the color of the springs, different pressure ratings for different H,P
/ Correct clutch kit for MF65 #3
G'day if you have a two stage clutch then that is your 9 spring 9 and 11" assy if you only have single stage then that will be a 6 spring 11" assy
Jon
Thanks guys i have a 2 stage clutch (well i would have if the PTO clutch wasn't cooked!) Question answered, i'll order it.
Cheers
Guys,
Just to say - i ordered the clutch kit but then found a thread on another forum about adjusting the PTO clutch from under the tractor so i decided to give that a go. I found there was no protective plate under the clutch housing so the clutch was pretty full of rubbish but once cleared i was able to quite easily adjust the 3 adjusting nuts on the clutch while turning it by hand. I now have a second stage clutch pedal travel but i have not yet tested to see if the secondary clutch plate is any good - i'll put my hay mower on tonight and give it a go. I also need to make myself a cover plate.
/ Correct clutch kit for MF65 #6
hi oilystairs, thats great news, could you put a link up for the adjustment
cheers stuart
