Corn row cultivator mounting positions ideas needed.
   / Corn row cultivator mounting positions ideas needed. #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
As a farm kid, I used to cultivate corn with a rotary 3-point mounted cultivator behind a IH 656. Pretty ugly at times. If it goes a bit off-row, you have to correct and that means swinging the 3-point implement further off-row for a time (your error is magnifyed when you correct course). I hated that job. I have seen little mounted cultivators on the sides of small red tractors, and sure wish I could build up something that could work on my JD 3720. Its wide-front of course. And my corn field is pretty small these days, maybe 1/4 acre. I plant with a 2-row 3-point planter built of two JD 71 units on a toolbar, 30 inch spacing. I could use the tractor's loader mount arms to hang something on, each side. But underneith would not be as easy.
What if it was a pull-type implement? If it used the drawbar there would be less of that magnifying effect when you go off-row. It seems that some combination of wheelbase and drawbar length and sweep position could make it a better-tracking setup than the 3-point. Any input here? Ideas, other experience? Thanks.
   / Corn row cultivator mounting positions ideas needed. #2
   / Corn row cultivator mounting positions ideas needed. #3
Are you against using chemical weed control or is there a different reason your wanting to use a cultivator still?
   / Corn row cultivator mounting positions ideas needed. #4
As a farm kid, I used to cultivate corn with a rotary 3-point mounted cultivator behind a IH 656. ... If it goes a bit off-row, you have to correct and that means swinging the 3-point implement further off-row for a time (your error is magnifyed when you correct course).
... I have seen little mounted cultivators on the sides of small red tractors, and sure wish I could build up something that could work on my JD 3720. ... maybe 1/4 acre. ... 30 inch spacing. I could use the tractor's loader mount arms to hang something on, each side. But underneith would not be as easy.
By pull type, do you mean something like a trailer axle, with the sweeps mounted off a crossbar mounted somewhere between that axle and the
hitch? Maybe a lift cylinder running off your remotes? Sounds like it would work, but I'd worry about it tracking right once the sweeps engaged if they hit a rock, larger weed, or harder patch of dirt, depending on how light you made it. Though if it was heavy enough a set-up, that likely wouldn't matter. Also, you might need more room to turn around at each end of the row to be able to get the "trailer" to fall in line with the direction of travel before starting each pass.
A couple of other ideas, how about mounting a crossbar to mount your sweeps off you front bumper? It would at least be easier to set up and adjust the center sweeps that way. I just don't know how having two sets of tire tracks pass over your just-cultivated section would mess it up, though.
How much old farm equipment is around you, might it be easier to find an old tractor already set up with the midmount cultivators? Like a Farmall Cub or an Allis B or G?
Might get old fast for a 1/4 acre, but how about getting an old two-wheel walk-behind tractor, like a David Bradley or Planet Jr. and cultivating one row at a time? I worked for one old timer that used a hand cultivator tied behind a lawn tractor! (with two people, and the deck removed). Though that was just for the first pass so he could get real close once his cukes sprouted; when they were well established he switched to a D-14.
Thanks for the input so far. To answer the questions:
Yes, would like to mimimize the checmical application. Also, sweetcorn benefits from the aireation of the soil due to cultivation, and cultivation also helps to brace it for wind --(did I get those right, you experts?).
Trailer idea feedback-- Yea, it would be kind of a pain to get it straight at the beginning of the row, hadn't thought of that. And also the light weight getting knocked off-course -- sure, that makes sense. Could maybe add weight to keep it from being upset, would need to experiment.
And more good ideas there too, to use the front bumper, although that sounds tough to see what is happening, gotta think thru that.
The existing equipment, like the Cub or Allis -- yea, I suppose if I was more serious with acreage, but I really only want one horse standing around. Those cultivator tractors were kinda specially configured with high clearance and adjustable width, really neat as I remember. I am afraid that I will not find a good substitute for their purity of design.
Another thing keeps popping up in my mind, so I will mention it. So, let's say for simplicty I just configure a toolbar 3-point cultivator. And I drive slowly and carefully, after all it is a small patch. But what if there was a hydraulic option of side-shifting the toolbar to align it as I drove along roughly in the correct track. Almost seems like a two-person job as I explain it. Probably crazy.
   / Corn row cultivator mounting positions ideas needed. #6
We plant a LOT of sweet corn and sure, I miss the cultivators on our Massey from the 1950's. Like a Farmall, you cultivated by looking down toward your feet. That is why these small, but tall tractors were so popular on tobacco road and with us produce farmers.
Today, I can use this cultivator and do every other row, if you are careful. It's isn't as good as the old days, but it's fine. But once the corn is over 8" tall, you're about done. I do still "run the rows" with a walk behind. It's not nearly as much work as it sounds. You can cover the ground quickly as all you're doing is quickly tilling and/adding side dressing.
   / Corn row cultivator mounting positions ideas needed. #7
But what if there was a hydraulic option of side-shifting the toolbar to align it as I drove along roughly in the correct track. Probably crazy.
You know what they say: If it's crazy but it works, it's not crazy.
It sounds like it's be a pretty simple build, one cylinder, a couple of mounts and some telescoping tube could get you there pretty quick.
If it saves you from knocking out a half a row or so of corn, why not?
Now if you set up a construction laser pointing along the row, a sensor at the tool, an electric valve, and a microprocessor to keep it all coordinated, that'd be crazy...
   / Corn row cultivator mounting positions ideas needed. #8
I have the very same cultivator, a TSC special. I put 7" sweeps on mine instead of the chisel points. Pop a set of guage wheels on it and just cultivate 1 row at a time. To me it is just too hard to keep an eye on two rows back there!!
   / Corn row cultivator mounting positions ideas needed. #9
If you could get the toolbar heavy enough, you could put rolling coulters just at the edge of each of the rows to help keep the unit from skipping around if one side grabs harder than the other. And if you had the coulters, you could mount a liquid fert knife just behind one coulter on each row and inject liquid fertilizer at the same time. Just put a TSC 12volt dc pump on the toolbar, and pop a small tank on with some sprayer hose and a regulator. Voila!!
WINNER !!!
This is what I want. I have been trying to get around to putting a liquid fertilizer application system on the planter to put a band of starter a couple inches away from each row when planting, but haven't gotten around to that yet. Perhaps I skip that and add fertilizer to the cultivator. That gives additional motivation to get out there and cultivate once or twice.
Now I need photos of existing stuff to copy from. I gotta look around and find a farm machinery junkyard kinda place near me here in SE MN, near Rochester.
   / Corn row cultivator mounting positions ideas needed. #11
We call it cultivator blight when we make a bobble lol. Farmshow had a man that built and sell hydraulically side shifted cultivators. I have a one row I pull with the big Yanmar with the inner teeth off and wide sweeps on the next set. I normally like using one of our Cubs for cultivation. We cultivate and later distribute ammonia nitrate in a spreader and then run a set of hillers on a Cub or tool bar to hill the fertilzer up on the the plants. It holds them and helps aerate the soil. If you had an willing helper an old attachment called a wiggle hoe would work. Its a ride on cultivator with lang levers to run the cultivator in and out. A new variation on this is called a Reigi Weeder.
Video Clip: Weed Em and Reap Part 1. Reigi Weeder - eXtension
That thing is cool. Is that the right tool for corn though? I was thinking I wanted something that would hill the dirt up to the plants.
   / Corn row cultivator mounting positions ideas needed. #13
You could try a regualer one row set of cultivators and add a tool bar to run a setto fo disc hillers to hill the corn.
   / Corn row cultivator mounting positions ideas needed. #14
I picked up 4 "hiller" units from a neighbor who tossed them on the scrap iron pile. Once I get my toolbar finished I will bolt it to my TSC 1-row cultivator to move soil up around the base of the corn plants and also put down some Prowl 3.3 EC herbicide at the same time.
Pics below show the hiller unit just mocked up to the cultivator to place mount points.
   / Corn row cultivator mounting positions ideas needed. #15
If you mount a coulter wheel in the center of your planter it will create a ditch for a similar coulter to run in on your cultivator, thus keeping a 2 row cultivator centered. You'll find a lot of these 2 row cultivators with a center mounted coulter wheel on craigslist. Lilliston rolling cultivators are good for hilling corn or you could mount some discs or just mount a wide sweep at a steep angle.
Dougg, is the coulter added to the planter to be mounted in front of the planter units? Or behind the planter units? I assume ahead of the planters. Any pics of this setup? Would it be just one coulter? Seems like that would make a slice, but not really a furrow. Could it be a sweep instead? That would make a shallow furrow. Thanks for the help.
   / Corn row cultivator mounting positions ideas needed. #17
Used to cultivate with a front (really mid-) mount cultivator on an IHC 300 tractor, then an Oliver S77. They worked will, easy to see/control as you say. I've seen up to 8 row wide versions, I've heard of 12 row models - they really surround a tractor!
Then used a rear 3pt mount, yes it took a learning curve to get good with it, but in a year I was able to do as well with it. The big coulter does help to keep it trailing straight.
Four and 6 row models are selling for $3200 a ton right now, no one wants them. Go to a few farm auctions around you & pick up all the pieces you need for scrap price.
Forget the trailer idea, does not work, they will pull to the side bad...
There are fancy side-shift controls, hyd, even with feelers to auto-adjust. You don't want to know what they cost new, they too are selling for scrap but tend to be rather big 8 & 12 row stuff....
Wouldn't be too hard to build up a mid-mount cultivator for yuor tractor from some scrap parts.
Drive slow and careful with the 3pt, one learns how to do it with a little practice. I realize the learning curve could be very hard on your small patch tho. :)
--->Paul
   / Corn row cultivator mounting positions ideas needed. #18
   / Corn row cultivator mounting positions ideas needed. #19
I grew up with the little Fords and 3 pt equipment. Cultivating is difficult and exhausting steering from the rear, so to speak. We picked up a used guide pointer that had a clamp bolt that mounted to one of the front axle adjustment holes. The pointer rod dropped through the clamp and was adjusted to just above the corn row. Someone said it was actually a Ford part. Very easy to steer with that. You could make something similar.
   / Corn row cultivator mounting positions ideas needed. #20
Wow, never saw anything like that. Be interesting to watch the ground wash away on my rolling hills. :) Probaly a little labot intensive for several 100 acres of corn & beans? But a cool thing in it's place, neat link.
--->Paul
Around here we call that an Eco Weeder. Very expensive... a one row unit is over $4,000.
Univerco :: Products :: Weeders :: ECO I
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
