Cork gasket sealant and more....
   / Cork gasket sealant and more.... #1
jachamar
Burlington,NC
I have a 2000 diesel '71.What kind the sealant do I need for the Camshaft Cork gasket (no holes)? I do like the Permatex Aviation Form-A-Gasket 3 Sealant,but I am open to any suggestion.
2- What do you think about the mess around the Bell house and shaft area ? Is It normal or you think i need replace the gasket also ?
Any idea ,advice It is very welcome.
Thank you in advance
PS Everything started with the "innocent"... :mad: frost plug replacement:.But I like to do a good job.
   / Cork gasket sealant and more.... #2
I use a couple dabs of weatherstrip adhesive and glue it in place. The block, and engine plate should be dry, or the gasket will squeeze out of place.
   / Cork gasket sealant and more.... #3
About the bell house and shaft area.
That mess is pretty normal but after all that work with taking the tractor apart to this point, I would go a little further. At least I did on my 4000 and that turned out to be the right decision.
There are oil seals for the shafts and if any of these are leaking you will get transmission oil right into your clutch assembly. That may not be the situation for the moment, but I would renew them now when things are apart. I did and when the "axles assembly" (retainer with pto axle) where out, I discovered that the bearing in the assembly was worn. It is very easy to take things apart, this is what I did:
Drained the transmission box.
Cleaned the bell house (I got half a gallon of dirt).
Disassembled the clutch release arrangement.
Removed the axle for the above, just to renew its bushings.
Detached the retainer (the inner set of screws) and withdrawed it.
Took the retainer and pto axle apart and renewed bearing and seals.
I also detached the big plate, just to renew its gasket.
Then I put things together with new gaskets and a new clutch release bearing.
When you reattach the big plate it is important to set the srews squarely, as the shop manual says, it is thin and might crack if set unevenly.
You have the related parts here:
New Holland 2000-SERIES 3 CYL TRACTOR
Choose Transmission...
Choose 07S02 MANUAL REVERSING TRANSMISSION GEARS & RELATED PARTS - 2100, 3100, 3400, 3500, 3550, 4400, 4500
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2004 JOHN DEERE 310SG EXTENDAHOE BACKHOE (A53843)
2004 JOHN DEERE...
