Core Aerators
   / Core Aerators #11
JDTRAC said:
Thanks for all the useful feedback. Results on some follow-up on my own...
My local JD dealer indicated the most efficient implement would be the three-point hitch Frontier 1048 4 ft core aerator. It has an operating weight of 316 lbs (prior to adding any additional weight) which should work fine with my 2305. And does a great job. However, as JDFANATIC pointed out pricey at around $2000. Unless I can find a second-hand model, the JD Tow-Behind 48-in plug aerator could be an option. However, it is primarily for the X500 and X700 series garden tractor and a little small (according to my dealer) for the 2305. Although would enjoy adding the Frontier aerator to my implement collection, must also question the investment for perhaps 2x/year usage. I will also follow-up the Trac-Vac 3pt suggested by kvjohndeere.
The Trac Vac 3 pt hitch Core aerator is set up like the Frontier & is Also 48"
   / Core Aerators #12
Husquvarna (sp) makes a 200 lb, 48" tow behind aerator that looks pretty good, and the price is perhaps $500 or so? Most dealers that sell their tractors should be able to get you info.
   / Core Aerators #13
I have a Woods PL60 core aerator that is a very well built unit. You may give one of these units a look. They have a 48 inch wide unit also that weighs around 437 lbs. As I said mine is a 60 inch and I paid $1800 last year for it. Good luck hope you find a good deal on which ever brand you get. Here is a link to their web site.
Woods Equipment Company - 48'', 60'' & 72'' Pluggers - PL Series
   / Core Aerators #15
agrifab at Sears is $299, sounds good and looks sturdy enough for 2x a year.
2020 Kubota BX23S TLB Compact Tractor (RIDE AND DRIVE) (A50775)
2020 Kubota BX23S...
2014 Electric Cart (A53424)
2014 Electric Cart...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2016 FREIGHTLINER...
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
20'x30' All Steel Carport (A53316)
20'x30' All Steel...
2005 Toyota Highlander SUV (A55758)
2005 Toyota...
