Cordless phone with good range
   / Cordless phone with good range #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
I'm looking for a cordless phone with enough range to use around the house and yard. Nothing fancy, just a consumer-quality phone with a range of perhaps 200 feet so I can talk when I'm out in the shed without having to run wires. I'm sure someone here has something that works.
Thanks.
   / Cordless phone with good range #2
i've been thru a bunch of different brands: have 3 different ones that i use right now: and nothing that works reliably any where near 200ft: now if i put the base unit outside, that would make a big difference: could you put the phone line in a protected area outside and hook the base unit there?
heehaw
   / Cordless phone with good range #3
If you have electric in the shed, I would go for one of those new types that use the one base to plug the phone line in and then run several cordless phones off of it with each cordless phone having a dock to charge on. The cool thing about these is that you can use it to call other phones in the house. I have the motorola 5.8 ghz and love it. I have used it at distances of up to 600 feet away from the base. On my motorola I have the base unit and 6 handsets. With all of that, I am only using one phone jack in the living room.
Good luck,
Steve
   / Cordless phone with good range #4
I have a panasonic. it's a kxtga523 (about 2 years old so there's probably a newer version out). It's a 5.8 ghz unit, and you can add as many stations as you want. The base station has a built in digital answering machine. I'v gone about 230 feet out of the house, and into the barn, and can still talk perfectly. Cost about a hundred bucks.
anthony
   / Cordless phone with good range #5
I've got a cheapy GE 2.4 Ghz cordless from Walmart. It works over 200' from my house. I had it in my shirt pocket while snowplowing my neighbors driveway with the tractor. I was about 250' from my house when it rang. It seemed to worked fine. I don't know how much further it would have worked.
   / Cordless phone with good range #6
I have the same as AnthonyK and know I've been up to 300ft from base unit till I start loosing signal. I have the base unit in trailer and two handsets in the shop and one in the shed, I have no problem getting to a phone.
   / Cordless phone with good range #7
One of the reasons I like to spend more time in the garage is to "get away" from the ringing phone... nothing but tractor noise.
mark
   / Cordless phone with good range #8
check out ebay they have portable phone with range up to 70 miles
   / Cordless phone with good range #9
I boght a senao phone on ebay, it will work up to 7 miles (not 20) like they claimed. The seller was in china, and it arrived in good condition.
I think it was $169.00 with shipping included. Oh its also a flip phone too.
Ernie
   / Cordless phone with good range #10
70 miles! Shoot, I could get rid of my cell phone if I had a portable that had ranges like that. :D
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2013 Big Tex 16GP-20 Gooseneck Trailer (A50860)
2013 Big Tex...
2012 Mitsubishi Fuso FEC72S 16ft Box Truck (A48081)
2012 Mitsubishi...
2019 Ford F-550 V-Mac DTM70 Air Compressor Flatbed Truck (A48081)
2019 Ford F-550...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
