Cordless impact to crank trailer jacks
   / Cordless impact to crank trailer jacks
This is an adapter I made for my travel trailer in case the motor went out on the electric jack. I don't know why a person couldn't make something similar for an equipment trailer. It was made to use a 3/4" wrench, crescent wrench or cordless drill with a socket.
That’s exactly the sort of thing I need.
   / Cordless impact to crank trailer jacks #22
I’m not sure how your jacks are made but mine have stubs out both sides of the jack. One side has a pipe with a bolt through it for the handle and and the other side doesn’t do anything. I’d planned on permanently attaching the drill stub to the vacant side and trading the bolt for a pin. If I wanted to use the drill I could just pull the other pin so the handle isn’t flailing around.
Thinking of doing same. Wonder if welding 1/2” impact socket on
   / Cordless impact to crank trailer jacks #24
I think some of the replies have confused stabilizing jacks on RV with lift (landing) gear on front of your trailer. A handheld cordless 12 volt drill will easily turn RV stabilizer jacks to run them up or down. Been doing that for years. But the RV stabilizer jack is NOT lifting the weight of the RV.
To manage the weight on front landing gear of a gooseneck or fifth wheel trailer you need something with slower speed and more torque. I am curious if you can get a variable speed high torque 1/2 cordless impact to do the job?
I use the cordless drill on both the stabilizers and the landing gear. The pin weight on my trailer is about 850lbs.
   / Cordless impact to crank trailer jacks #25
This is how the landing gear works on our Timpte Super Hopper grain trailers. The handle works on the landing gear and the dump doors. I wonder if you could weld a nut on the end of the shaft to use a drill and fix your handle similar to this.
Screen Shot 2020-09-22 at 9.29.20 PM.pngScreen Shot 2020-09-22 at 9.30.09 PM.pngScreen Shot 2020-09-22 at 9.30.35 PM.png
   / Cordless impact to crank trailer jacks #27
Hummm......:confused:
Just showing how Timpte does it. The handle has a hex socket that fits the hex nut on the shaft. A person could use a drill (or impact) to run the legs down and finish with the handle.
Here is my jacks & handle
   / Cordless impact to crank trailer jacks #30
I used that brand before, Then we started using Holland legs....
2020 JOHN DEERE 6145M LOT NUMBER 79 (A53084)
2020 JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
