Cordless Grease Gun Storage
   / Cordless Grease Gun Storage #1
KennK
NE Wisconsin
John Deere 3320
Santa surprised me with a Dewalt 20V cordless grease gun. Much needed given age has brought with it a bit of arthritis in my hands, and I try to be good about frequent lubrication of my tractor's front end loader.
My manually operated grease guns are stored in a bucket to catch the inevitable grease/oil drippage. That leads me to wonder ...
How do I store a cordless grease gun so as not to destroy the electrical components? It came in a set with a nylon bag and a 1/2" impact wrench, but I fear the grease would make a mess of the inside of the bag. My best guess is to find an appropriately sized tub or bucket, and store it sitting on its feet - with the grease tube on the bottom and the electrical portion on the top.
Your advice and experience is very much welcome!!! By the way, I have an extra Lock-N-Lube tip ready to install on it!!
Oh, is the pulsing sound roughly equivalent to the number of squeezes of a manual grease gun? The manual doesn't say. My WoodMaxx snow blower manual warns not to over grease the bearings (only using 1-2 pumps of grease rather than pumping until fresh grease is visible.)
   / Cordless Grease Gun Storage #2
Congrats! Nice gift.
I have managed to collect 4 of the DeWalt 20v guns with cases. I keep one in my service truck, and one in 3 of my 4 tractors.
The grease guns fit perfectly in the rugged plastic cases and the plastic cases are very protective.
And yes, the pulse, or click is pretty much equal to a pump.
Merry Christmas!
Sometimes you can find empty grease gun cases on Ebay for ~ $20
   / Cordless Grease Gun Storage #3
I make sure to never leave the battery in it, I use vinyl gloves when I grease and when I'm done I wipe off the gloves and slide the grease nozzle into the finger hole then sit on a rag on the shelf.
   / Cordless Grease Gun Storage #4
I got my lube shuttle today for Christmas. No more messy grease for me.
   / Cordless Grease Gun Storage #5
My dewalt gun came in a plastic case. I’m generally not a fan of tool cases but I keep my grease gun in the box to help contain the mess.
   / Cordless Grease Gun Storage #6
I also have the hard case, and wrap the fitting in a shop rag for storage. I wouldn't keep it with other power tools in a bag.
The DeWalt electric grease gun and LockNLube is a great combination.
   / Cordless Grease Gun Storage #7
Please don't store it near a heat source.
I was gifted a used powered gun and all the clay based grease was so hard that I had to pry it out but the efforts were well worth it.
I only use non clay based now having lived that experience.
I did however learn a trick as when cleaning that gifted gun the phone rang.
My hands were 'overly greasy' and needed cleaning FAST!
Not having a solvent cleaner handy I quickly squirted my hand with a quick squirt of WD40 and to my great surprise one quick wipe with a shop rag had them spotless.
Following that a normal soap and water wash had them spotless.
   / Cordless Grease Gun Storage #8
I'm another fan of the DeWalt 20V grease gun. I don't bother storing it in the plastic case since the leakage makes such a mess. I stored the gun on it's feet in a shallow plastic tray for a while but it required cleaning the tray frequently. Lately, I've been standing it on end with the grease tube up. I was concerned about the motor at first but there is no leakage at all as long as the grease tube is seated properly.
   / Cordless Grease Gun Storage #9
1 ca-chug = 1 pump as far as I can tell. Piston volume on the electric may be smaller. It's easy to compensate for that with the speed they run though.
I store mine on a bench & wipe up under it with rags I'm about to toss. The relief valve is really messy & impossible to fully clean if it pops. Haven't used the manual ones in a few years. They are hanging in a nasty 5 gallon bucket as they always have been.
The Dewalt & Lock 'n Lube is way easier than a manual, but not really much cleaner. I still clean zerks with a rag to avoid pumping grit into the zero. Ooze out of the nozel, joints you are greasing, etc. Always use gloves. I use the cheap fabric ones that have been dipped in rubber on one side. They breath way better than latex disposable ones.
   / Cordless Grease Gun Storage #10
I have the Milwaukee 18v version and all I do is pull the battery, Wipe off the hose and stick it in it's holder and throw it on the shelf. Never oozes grease like my manual guns do.
40' CONTAINER (A51244)
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2003 Big Tex 10PI...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
