cord wood saw ideas?
   / cord wood saw ideas? #1
ger
I've never used a cordwood saw but have cut too much wood with a chainsaw. I don't have a pulley on my tractor to run an typical old saw so was wondering about making my own- possibly a PTO powered bandsaw type of thing. Anyone with input?
Thanks; Gerald
   / cord wood saw ideas? #2
Stick with the chainsaw, it is safer. If the saw you are referring to is a circlular one they are dangerous. They are made to run with a flat belt so if you have a problem they will slip, no slip with a pto shaft. They also need at least 2 men and 3 are better to safely use them.
   / cord wood saw ideas? #3
Do search a for Buzz Saw here on TBN. You will find several threads on them.
Here is one thread. Click Here
I have sold mine.
After you have run one for a few minutes you will know why its called a BUZZ SAW. /forums/images/graemlins/frown.gif
   / cord wood saw ideas? #4
I have used a buzz saw for many years and still have all my fingers,I only use it for slab wood or branch wood that is less then 4''. Running a buzz saw is a 3 person operation,1 to feed , 1 to cut and 1 to throw, They are also good to put a sharp end on a fence post. If you want to saw bigger then 4'' use a chain saw. As far as a belt drive, I have a 8n and the large pulley bolts to the PTO and is offset 90 deg's.
Good luck Sam /forums/images/graemlins/wink.gif
   / cord wood saw ideas? #5
About one year ago I had a friend offer me a 3 pt buzz saw he had in the back of his shed. I told him I would try it and see if I wanted it. As a one person wood cutting operation, it was not as handy as using the FEL to lift and cut with the chainsaw. I brought it back.
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2007 FELLA SM350 3 PT DISC MOWER (A52748)
2007 FELLA SM350 3...
