Loader Copper hydraulic lines?
   / Copper hydraulic lines? #1
jiminsulator
Buffalo, New York
cabellas wlm 35h
Any one have problems with hard hydraulic lines, had one work harden and break.. only 50 hours on machine.. line was copper!! It's a return line it still...
   / Copper hydraulic lines? #2
If theres a filter in the return there may be some pressure. Seems like it would be safety bypassed at way less than 200 and copper would take that. Is there a lot of vibration or perhaps a return obstruction? Did it spurt violently?
   / Copper hydraulic lines? #3
Is this seeing vibration? Suspect yes since that would lead to work hardening and breaking. I have seen this happen on oil cooler lines on other brands of tractors.
   / Copper hydraulic lines? #4
Replace the vibrating section with hydraulic hose. The copper is surprising as steel seems to be standard for dynamic things like tractors. A short piece of hydraulic hose where it broke may help also. Copper get brittle way faster than steel.
Ron
   / Copper hydraulic lines? #5
Copper as a return to tank line is fine. Mounting an fixing against movement may be an issue, I'm sure you can meet that challenge!
Make up a new line, secure it well.
It's under warranty and needs its 50 hour service so I'll have them replace it.. but if I have more issues I'm gonna replace with steel if they don't..
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2019 FORD TRANSIT 350HD VAN (A52576)
2019 FORD TRANSIT...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
