Cooler Holder
/ Cooler Holder #1
Swisher
Bremen, GA
JD 22110
N-Frost has a nice looking cooler holder on his tractor, that he made himself.
I have no welder or torch, but wanted a cooler holder for my JD 2210, I was in Ace Hardware the other day and picked up a 4qt feed scoop, went a couple ailes over and found the 1/2 gal cooler, it fit right in but a little loose,
brought them home, and took a bracket and fastened it to the back of the scoop, then painted it, had some double sided insulation left over from my garage doors, cut and fit it inside the scoop, got two square U clamps and plates to fasten it to the ROPS.
/ Cooler Holder #2
That looks like it will work swell. So where on the tractor are you going to put it?
/ Cooler Holder
Will post a picture when I put it on the tractor.
/ Cooler Holder
Here are some pictures, I think I will be moving it iF and when I get a flat canopy, will move it to the other side on the back of the ROPS, realy don't like having things inside of the work station.
