Coolant Replacement - Kubota B2910
   / Coolant Replacement - Kubota B2910 #1
MIKEKUBOTA
Kubota 2910
Yet another question. The coolant in my Kubota B2910 is scheduled for replacement. The manual directs the use of PT (Permanent Type) antifreeze.
Can I use an antifreeze such as Prestone or Zerex, or do I need a low silicate formula similar to the antifreeze that is required for a diesel F350?
Are any additives needed to forestall cavitation?
   / Coolant Replacement - Kubota B2910 #2
</font><font color="blue" class="small">( Yet another question. The coolant in my Kubota B2910 is scheduled for replacement. The manual directs the use of PT (Permanent Type) antifreeze.
Are any additives needed to forestall cavitation? )</font>
I use Prestone Yellow in my volvos. 5 yr antifreeze that apparently is very safe to al engines. But don't trust what i say, make sure for yourself.
Bob
   / Coolant Replacement - Kubota B2910 #3
Mike " I like the name" do you have the D1503-ELA-2 engine? /forums/images/graemlins/wink.gif
May the force be with you!
If I'm reading the correct reference it is Model V1505-E-D16.
   / Coolant Replacement - Kubota B2910 #5
Okay this is a " liner less type " block according to sales literature and therefore you don't need to worry with 'DCA' additative in your coolant. Only engines with "wet liners" are subject to cavatition. /forums/images/graemlins/smile.gif
May the force be with you! Ob1
Thanks for the research!
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
Kivel 3500 Lb Pallet Forks (A50121)
Kivel 3500 Lb...
1997 Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
1997 Cat 953C...
2014 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
2008 Ford Bucket Van (A50323)
2008 Ford Bucket...
