Coolant Question???
/ Coolant Question??? #1
scsims
Central, KY
Mahindra 5525
I was thinking when I should flush my coolant system. I have a 5525 that's about 2 years old with 58 hrs. The manual says change interval is once a year or when ever you drain the coolant.
Then the maintenance schedule says every 1000 hrs. Do you guys flush your coolant yearly? If so what brand do you use to refill it?
/ Coolant Question??? #2
Almost no one changes the coolant regularly. JD Cool-Gard II claims 3000 Hrs. Test strips will tell you the condition of your coolant. When you do flush and fill, be sure to use a coolant with the proper additive package for diesel engines.
Where are these test strips available at?
/ Coolant Question??? #4
Should be available at your dealer or most any parts store.
/ Coolant Question??? #5
If you do change the coolant, consider the "Fleet Guard" at tractor supply. It is made for HD diesel engines and is probably less expensive than the dealer. Diesel engines should have low or no silicates in the coolant so steer clear of the automotive type.
2017 Hyundai Sonata Sedan (A64557)
2017 Hyundai...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2022 International LONESTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2022 International...
