coolant question
   / coolant question #1
RollingsFarms
South Carolina
Few John Deere's and one Ford 3600 diesel.
the coolant that came in my tractor is blue. i had a small leak a few days after i got the tractor. i noticed my coolant was a bit low and traced the leak to this, so i just tightened up the screw some and its been fine ever since. i do have a few questions though. i wanted to top off my coolant, so i went to the dealer and purchased some. the problem is it's purple and i didnt really want to mix them. so, i added a little bit of water to the coolant tank. is this ok? does anyone know if the blue coolant in my tractor is summer or winter coolant? the reason i ask is because i have a bottle of JD summer coolant and its green but the JD winter coolant is purple.
   / coolant question #2
Yikes! Blue now?
   / coolant question
Yikes! Blue now?
it was blue from the factory. the tractor only has 12 hours on it. i didn't mix the summer or winter coolants i bought from JD because they were different colors so i just added a little bit of water to bring it back up to the "full mark".
   / coolant question #4
Could it have been watered down to make the purple turn blue? I've never seen or heard of a blue unless some kind of anti-rust or extended was added.
   / coolant question
could be. like i said, it was blue the day i bought the tractor as i went over and checked all the fluid levels when it was delivered. had a coolant leak, so i went to buy some winter coolant since all i had was summer coolant. got home and noticed the winter coolant was purple but the summer coolant i have is green. so i said the heck with it and just topped it off with water. would that be ok? i didnt want to mix coolants.
   / coolant question #6
If it wasn't alot of water it shouldn't hurt, better than putting in the wrong coolant.
You may ask your dealer what coolant was put in, he may know.
Purple,red,orange,yellow,green,amber, I've seen all these, who knows, maybe we need a blue.:D
If you contact your dealer let us know what his thoughts are, but you should be fine if you added a little water.
   / coolant question #8
Man, I don't know about the different colors, but adding a little water is OK.
Did you use distilled water?
I've read where the normal 50/50 mixture should err on the water side. That is, as long as the mixture is enough for freezing and lubricating protection it's better to have slightly more water than anti-freeze. If there's too much anti-freeze, the engine could run a little hotter than normal.
   / coolant question
i just used an old gallon milk jug that i use to carry water out to my dogs and got the water out of the sink. didnt fill up the jug, not even close, just put enough in it to bring the coolant level back up to the line. id say it was a little over halfway empty. i ran the tractor some today loading a box blade into a trailer but noticed the tractor never really warmed up.
   / coolant question #10
Cummins has been using blue antifreeze for years. My Snap On dealers truck has it in his Cummins powered Freightliner.
Livestock Hay Ring - Round Bale Feeder (A55218)
Livestock Hay Ring...
Krause Dominator 4850-18ft (A55301)
Krause Dominator...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
