Coolant Presence Sensor. Any experience out there?
   / Coolant Presence Sensor. Any experience out there? #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I would like a coolant presence sensor for one of my generators. There is no reliable way to measure temperature in the absence of coolant. Most sensors will actually show a cooler reading after your coolant is gone! Then the real damage starts, and finally your probe may get heat through convection, or conduction, but the damage is probably done.
All the coolant presence sensors and systems I found are strangely in Australia.
The most interesting one was made by Montronics, is stand alone, has a 1/4" NPT mounting and internal transistor switch.
I tried to E-Mail SALES, and had my E-mail deleted, unread. Discouraging.
My phone plan doesn't cover Australia.
Any knowledge of such devices out there?
Murphy has a chamber with a float that has to be plumbed in, but that is too big and involved for this project.
   / Coolant Presence Sensor. Any experience out there? #2
How about a windshield washer level indicator from any of the dozens of models/manufacturers that use them??
Many such sensors do exist, to go in the recovery bottle, but would not survive the radiator environment. Most are plastic.
   / Coolant Presence Sensor. Any experience out there? #4
As are most radiators.
Does your generator have a recovery bottle? If not, add one?
It does. I bought one but I don't know how that is supposed to work. The maybe two feet of hose has no coolant in it, so it first has to get filled with hot coolant. Plus, I could find no information on mounting height or location of such a tank.
But in general. I don't think a release of coolant, due to a ruptured rad hose, will cause any indication in your recovery tank.
They say that the tiniest bit of dirt under the rubber flange can render such a recovery system useless. I have never been under the impression that they work well.
   / Coolant Presence Sensor. Any experience out there? #7
ive replaced coolant level sensors on generac liquid cooled generators in the past. they do exist....
   / Coolant Presence Sensor. Any experience out there? #8
Two answers here.
How a recovery tank works is if the radiator gets too much pressure and pukes out fluid it is caught in the tank. Then when the system cools the hose draws the fluid back into the radiator thru the two way cap.
I agree. A blown system that instantly causes the machine to lose all coolant will not be indicated by a sensor in the still full recovery tank.
What you need is a heat sensor similar to a heat gauge sensor. This sensor then needs to be wired into the run system of the engine. So overheated condition causes ignition shutdown.
I've saw these systems for oil pressure and heat used on tractors that power stationary systems such as a grain dryer or irrigation pump system. No operator needed to monitor engine.
Not sure what to tell you to search for to find that in Google. But I know they exist. Go out West into AG irrigation country and you'll see stationary engines pumping irrigation water with no one around. No doubt they have this protection.
I looked into a cylinder head temperature sensor, but have no place (I know of) to put it on this ISUZU 3LB1 motor.
I had installed a new bung on the new Yanmar Rad I got off E-Bay, to accommodate my electric fan thermostat. I ran the motor and watched with an infrared thermometer. The temperature was climbing but the fan wasn't coming on. It seems that the motor was purging itself of air and the rad level was down, to the point that my sender was not seeing coolant.
And that started my paranoia!
   / Coolant Presence Sensor. Any experience out there? #10
You might try some places that service standby generators. I think all of the newer ones we have at work have a low coolant sensor. They are threaded into a bung at the top of the radiator tank. I don't know if one will work however stand alone since the generators are controlled by a PCM.
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2013 CHRYSLER 300 (A56859)
2013 CHRYSLER 300...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
