Coolant Overflow?
   / Coolant Overflow? #1
tinsnip
Maine
2006 JD 4120
I noticed a small stain on the barn floor under my 4120 (purchased new this Spring). After some poking around with a light, I have determined that the fluid is coolant (bright green), and that the overflow reservoir shows a level that's about a half inch below the "cold level" line.
I check my guges pretty frequently, and noticed no signs of overheating. The gauge was pretty much exactly where it has always been during operation.
Is it possible that when I last used the tractor I might have shut it down too quickly and there was enough heat build up to force an overflow? At this point I can't say for certain that the "leak" is caused by the overflow, only that the level is down.
My plan was to use the tractor again today and see if I can witness anything that might provide a better clue. Obviously, if this is a symptom of a serious problem, I want to get the dealer involved and take advantage of the warranty. How concerned should I be?
   / Coolant Overflow? #2
Tinsnip, I found a loose cooling hose clamp on my 4120 last week. Small line just in front of the oil filter.
I was checking the oil before startup and noticed a bit of fluid there. Couple of turns with a screwdriver cleared it up.
You might want to check your hose clamp locations.
Bought the 4120 new in 11/05.
Jon
   / Coolant Overflow?
Thanks! Good suggestion. I'm hoping it's something as simple as that.
2013 PETERBILT 367 TRI-DRIVE (A55745)
2013 PETERBILT 367...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A55787)
2018 Bobcat T590...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
1999 MACK RD688S MIXER TRUCK (A55745)
1999 MACK RD688S...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
