Coolant in engine oil on a 5603?
   / Coolant in engine oil on a 5603? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
Local neighbors employee got the engine hot and now coolant is in the oil. I understand how the problem could be a bad head gasket or cracked head. I'm also aware of oil cooler & lining o-rings. But looking at parts schematic I don't understand if water pump can contribute to coolant in the oil? Could WP be the problem?Thanks,Jim
   / Coolant in engine oil on a 5603? #2
Water pump can't leak into the crankcase on this model. The water pump fits into the timing cover and possibly a porous timing cover could get coolant into oil. Haven't seen that happen, but is possible.
I thought from viewing parts schematic WP couldn't be the problem but I thought I'd ask. Thanks for reply,Jim
   / Coolant in engine oil on a 5603? #4
Oil pressure is far higher then coolant pressure. You have the potential of a head being cracked, block being cracked, cylinder sleeve or head gasket.
I just told my neighbor I thought he should pull pan,pressurize cooling system and look for drips. Cyl head has been removed, checked for cranks and new head gasket installed Thanks for replies,Jim
2005 TerraGator 8104 (A53473)
2005 TerraGator...
2019 Hustler Super Z 60in Zero Turn Mower (A51691)
2019 Hustler Super...
2010 Ford Edge Limited AWD SUV (A51694)
2010 Ford Edge...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
