Coolant; How much anti-freeze?
  • Thread starter Deleted member 41266
  • Start date
   / Coolant; How much anti-freeze? #1
D
Guest
I just learned that my buddy's 7520 may not have enough anti-freeze in the coolant. (Don't ask me how this slipped under the radar :eek:)
Temperatures out here, Chicago suburbs, went to -0- last night and I would like to take care of this on the coming weekend when it's due to warm up (low 50's if you can believe that).
Right now I think it's about 35%ish anti-freeze and I am going to take it to 50-55%.
My questions are:
1. Is there a radiator drain spigot on the 7520 and where is it or what would be the easiest way to remove 2 1/4 qts of coolant.
2. What is the factory fill supposed to be in these things, i.e. what % ethylene glycol?
3. Who in the sales process is responsible for adjusting the coolant for different weather markets--if 50-60% ethylene glycol is not the factory fill? I'm not out for blood, I would just like to know who, if anyone, you think should have caught this.
As usual thanks in advance.
Peter
   / Coolant; How much anti-freeze? #2
A good 50/50 mix of antifreeze should cover you down to about -30 deg. F
Sorry, can't help you on the 7520 radiator drain but there should be one.
   / Coolant; How much anti-freeze? #3
A 50/50 mix is where it should be, when you test it, it should test about -34 degrees. I think you have your degrees on the tester mixed up with percentage. I would test it again.
   / Coolant; How much anti-freeze? #4
How many hours on the tractor? You may want to do a complete change - I personally don't like to mixed different types/ brands of anti-freeze. Also is it a "wet" sleeve engine? I used global final charge anti-freeze it's rated for diesels. Just my 2cents Sorry I almost forgot when I can't find the radiator drain I pull the lower hose off the radiator -Ed
No mixup, Galen, the hygrometer said it was about 35% coolant--good for 0F. But, I will double check. The tipoff that we had a problem was when my friend, the owner, recently told me that when he checked the coolant last winter it looked frozen at the top of the radiator.:eek: I wish he had said something about this last summer...
Red55: As far as a change out goes, it is a good suggestion, but I think I will wait until it's a little warmer to do that. I just want to get us through the winter for now. We've got some HD silicate free diesel rated juice and, gosh, I hope that I don't have to pull a hose to do this.
We double checked the coolant and it was over diluted for out our needs; took out 2.25 qts and topped it up with 100% antifreeze. We're now good to go down to minus 30-35F.
I was in NY last weekend and was going by Batavia, so I dropped in to personally thank Galen for his online help. When I confirmed that the coolant was too weak, he then asked me "how old is the tractor?" I thought this was an odd question, but he explained: about 2 or so years ago Mahindra's factory fill was good to +0-5 deg F. Well, that's us!
So, to all you Mahindra operators, if you live north of the Mason-Dixon line or something like that ;) , you might want to check your coolant and make sure it is appropriate for the low temps (and higher summer temps, too) in your area.
Happy new year all.
Peter
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
JMR 40" Mini Root Grapple (A50121)
JMR 40" Mini Root...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
