Coolant gauge for 2005 Gator HPX Diesel?
   / Coolant gauge for 2005 Gator HPX Diesel? #1
aa777888
JD3520
Has anyone already solved this problem? Hoping to not reinvent the wheel. I'd like to replace the idiot light sensor with an actual temperature gauge.
Thanks!
   / Coolant gauge for 2005 Gator HPX Diesel? #2
Thanks!
Do you think it runs hot, and thus need to keep closer track of the temp?
Have you searched for an aftermarket gauge? Tracked the wires to a temp sensor? Do you have the service tech manual for your gator?
This link shows the HPX water pump and the location of the sensor (key #8), as well as a plug that might be removed to place a different sensor for a gauge.
Yes, yes, yes, and yes.
Fan not coming on. Fan tested OK. All wiring tested OK (jumpered at thermoswitch connector, fan comes on). Installed new thermoswitch. Idiot light and sensor tests OK. Water pump OK. Hoses OK. Thermostat also brand new and tests OK. New radiator cap (did not pressure test). System properly bled. Coolant level is stable during operation.
Could possibly be a bad radiator. I need to borrow an infrared temp sensor and measure heat across the radiator.
In the meantime it seems easy to add a gauge. Since I posted I've found out that the thermostat block has an additional port and that the port is an M20x1.5 thread (and if anyone can confirm that on this forum it would be great).
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2020 BERGMANN C815S DUMP TRUCK (A51246)
2020 BERGMANN...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2012 WABASH 53x102 DRY VAN (A53426)
2012 WABASH 53x102...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
