fieldserviceengineer
Bronze Member
OK.. did some more research and have a few questions.
Looks like my 7.3 PSD from 99 would have taken the coolant addative FW15 ( back then ).. and that is a SCA2 type addative. The addative I was thinking of using, the napa kool 4056 also appears to be a SCA2 addative.
At some point Fw15 was updated to Fw16.. not sure the difference.
Nowadays the spec is VC8 it looks like.. and that is a DCA4 adative ( nitrate and moybdate?? )
So.. question.. still ok to add the napa kool 4056 to my 99 PSD.. or do I need to pick up the VC8
whats the verdict from ye learned diesel owners?
soundguy
Ford FW16 is our Fleetguard DCA4. Older FW15 is the same but different part number based on packaging as I recall. Even if you use supplemental coolant additives (SCA) of a different chemical base such as Fleetguard DCA2 (nitrite only) or our DCA4 (nitrite, molybdate) and all the competitors out there, they are all compatible. No issues at all in mixing. If you use test strips to measure the DCA4 content, be certain to use strips that measure both nitrite and molybdate. There are test strips that only measure nitrite, thus they would indicate that there is less active additive in your coolant than reality. Use either Fleetgurard 3-Way test strips, CC2602, Donaldson same kit but different part number, Baldwin has same kit but different reference chart "look".
The use of the Ford SCA products was never based on whether the coolant was a conventional chemistry (non-OAT) and their present use of an OAT hybrid, Motorcraft Premium Gold. While Ford states that it is not necessary to add SCA to that coolant, it certainly does not hurt to add a pint on yearly basis as a maintenance dose. The chemical is consumed in protecting against cavitation corrosion (pitting). The PowerStroke (D444E) and earlier versions from International plus the 6.0 liter are all parent bore (cast-in cylinder block) designs, no liners. The new 6.7L Ford diesel, also called PowerStroke is a parent bore design. The International engines have all shown the ability to fail from cavitation. Use a supplemental coolant additive. A one time dose is not sufficient, regardless of the claims that Premium Gold does not need additives for a specified period of time. Better to err on the side of overly cautious than to learn how much it costs to have the block bored and sleeved to fix pitting damage.
