Coolant drain plug
/ Coolant drain plug #1
NB Canada
L3400 Hst
I have searched previous treads but I haven't found my answer...Does anyone know of a coolant drain plug on the engine block of a 2007 L3400HST?
/ Coolant drain plug #2
I could not find one on the L2800, so I disconnected the lower radiator hose from the pump. It still leaves quite a bit of water in the system. Flush through the upper radiator hose and the bypass hose till clear. Then flush with a couple of gallons of distilled water. Add half the cooling system capacity worth of straight antifreeze, then top with distilled water to the full mark on the recovery bottle. If I remember correctly mine the antifreeze filled the system up to the top of the recovery bottle, so I did not end up adding additional water.
/ Coolant drain plug #3
I also unhooked the upper and lower radiator hoses to make flushing the system easier.
/ Coolant drain plug #4
My coolant drain & plug are on the bottom of the radiator - nothing on the engine. I put a garden hose into the radiator fill port at the top and let it run for at least 1/2 hour after draining all the antifreeze. This sure seems to flush everything out of the system.
I guess if you want to get a better flush than that - drain all the antifreeze, flush like I do, refill with clean water, run the tractor 15-20 minuets, keep doing this until there is no color in the water coming out of the radiator drain plug. You could also use a coolant system flush chemical - I don't because it has to be some type of fairly harsh chemical and thats the last thing I want in the tractors cooling system. If its difficult to flush out the antifreeze - it will be just as difficult to flush out coolant system flush chemical.
/ Coolant drain plug #5
You could always knock a freeze plug out. If you can't find a drain on the block.
Sent from my GT-P3113 using TractorByNet
I appreciate the replies. In the end, I drained from the rad plug and flushed out the remainder as best I could with fresh water... I can't say that the old stuff looked bad. I filled the rad with Rotella ELC undiluted as this stuff seems to match the specs indicated in the manual. After I run the machine for a bit, I will check the mixture and top up the overflow as required.
This Rotella stuff is spec'd to last a long time and I really question the need to do this every 2 years. If it is so important to do so, you'd think that Kubota would have come up with a fail-proof method of performing this task. If the coolant looks good and the temperature gauge remains consistent, the stuff is staying in unless intelligently advised otherwise. :confused3:
/ Coolant drain plug #7
Most long life coolants are rated for at least 5 years, I changed my original fill at 2 years. It took quite a few fill/drain cycles to get clear water coming out while I was flushing. I added non-diluted coolant to what was left in the system and tweaked the mixture to get the right freeze protection.
Sean
Sean
Rotella Ultra ELC claims a life cycle of 8 yrs/12,000 hrs....so I should be good for awhile.
JOHN DEERE 1760 MAXEMERGE XP 12-ROW PLANTER (A62130)
JOHN DEERE 1760...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2017 Chevrolet...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
UNUSED KJ HD 5'HX5.6'L WIRE MESH (3 PANELS) (A62131)
UNUSED KJ HD...
207277 (A52708)
207277 (A52708)
2821 (A62131)
2821 (A62131)
