Coolant change?
   / Coolant change? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
Replace coolant On CT450 I drained out cleaned reservoir tank. How much to you put back in and do you fill the main tank first?
   / Coolant change? #2
Fill to the bottom of the radiator filler neck. Fill the reservoir to the fill line. Watch the level in the reservoir the next few days of operations, and add fluid if necessary. Some times there are air voids in the block that need to be worked out, and the fluid level will drop in the reservoir. You may or may not need to add to the reservoir a couple of times.
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
