Coolant change?
/ Coolant change? #1
HK45
Gold Member
Bethlehem, Pa
Kioti nx6010 loader backhoe
Replace coolant On CT450 I drained out cleaned reservoir tank. How much to you put back in and do you fill the main tank first?
/ Coolant change? #2
Fill to the bottom of the radiator filler neck. Fill the reservoir to the fill line. Watch the level in the reservoir the next few days of operations, and add fluid if necessary. Some times there are air voids in the block that need to be worked out, and the fluid level will drop in the reservoir. You may or may not need to add to the reservoir a couple of times.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
832624 (A61166)
832624 (A61166)
2015 SHOE1999 SER (A61569)
2015 SHOE1999 SER...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A61165)
2017 Mitsubishi...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Pinnacle...
