Cool Tip Soldering Iron
   / Cool Tip Soldering Iron #1
imported_OWDouglas
WNY
Has anyone tried or purchased this? If so, I would like your opinion on it. Thinking about getting one, but would like to know if it works, or a scam.
   / Cool Tip Soldering Iron #2
They are only good for really small stuff. Notice what they are soldering in the commercial /forums/images/graemlins/smile.gif
I am also not sure if I would like to solder on electronics with them as they put current thru the item being soldered.
Ben
   / Cool Tip Soldering Iron #4
Garbage... A buddy had one melt down on it's trial run. Smallish speaker wire. The batteries got so hot they leaked acid afterward.
Those folks in the commericals must have numb fingers as the tip doesn't cool down as fast as they show.
No refunds on it, only replacments.
Well that's all the input I need. I'll spend that 20 bucks eleswhere. (probably Harbor Freight) thanks everyone.
   / Cool Tip Soldering Iron #6
Ditto.. they are cr@p.
They can only solder like 18awg wire max.. and aren't any good on solder thicker than angle hair pasta. Besides.. like another poster says.. they run power thru 2 sides of the tip.. I'm not so sure how an ESD sensitive component might like the higher potential being generated on one of its legs.. etc.
Soundguy
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
JLG E300AJ (A50123)
JLG E300AJ (A50123)
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
